Need help with 94 GT
Old August 1st, 2011, 08:13 PM   #1
87coupe331's Avatar
1987 Mustang LX Coupe
87coupe331 is on a distinguished road
I just put a 90 GT motor in a 94 GT and I can not get any power out of it, the 94 motor had the same problem,
it will not even get out of its own way and is worse when it warms up. PLEASE HELP !!!
My wife wants to drive her car and she is making me crazy.
Any help would be very helpful. THANKS
Old August 1st, 2011, 10:55 PM   #2
1995 Mustang GT
Bubba95SN is on a distinguished road
Plugged exhaust.
Old August 1st, 2011, 11:16 PM   #3
91sleeper's Avatar
1991 notch
91sleeper will become famous soon enough91sleeper will become famous soon enough
whats your fuel pressure?
It can't be that fast cause it still has the stock hood.
-some punk
Originally Posted by flyin ryan View Post
8 sec 1/4 times are soo 2009. Im running 6 sec slips in my dd 302 pig with street tires
Originally Posted by flattusmaximus78 View Post
Nah not even stock form. I just made it up.
Old August 1st, 2011, 11:24 PM   #4
Daves94vert is on a distinguished road
Did you reuse the sensors? Maybe your coolant temp sensor?
Old August 2nd, 2011, 02:22 PM   #5
hotmustang95's Avatar
Last of the 302's
Road Racing Rookie
hotmustang95 is on a distinguished road
So it starts up fine and idles fine but it just wont move? Does it drive ok until it warms up? If the 94 engine did the same thing then I think it's not the motor doing it. Need more info. Maybe your brakes are locked. Maybe the rear end is too.
Victor ( goofyfeet) Oliver
P.B.M.C. Member
Track Addict
Old August 2nd, 2011, 02:28 PM   #6
01Sportchic's Avatar
1997 Mustang Cobra
11.87@115.97
01Sportchic will become famous soon enough01Sportchic will become famous soon enough
What Vic said, or maybe even something electrical.
Danielle
D. Perez Photography
http://img.photobucket.com/albums/v62/coolpersond/Cars/New%20Improved%20Black%20Beauty/sigtry2.png
Old August 2nd, 2011, 03:47 PM   #7
Bullitt95's Avatar
1995 Mustang GT auto
13.546 @ 105.32
Bullitt95 will become famous soon enough
Originally Posted by Bubba95SN View Post
Plugged exhaust.
Yeah I was also going to say plugged up cats. You could also try cleaning the MAF sensor element.
243.5rwhp/284.2rwtq
Mod list in My Garage
Old August 2nd, 2011, 06:38 PM   #8
87coupe331's Avatar
The cats have been gutted, fuel pressure is 38-40lbs, coolant temp sensors are new, and the rearend and the brakes are not locked up, also MAF sensor has been cleaned.
starts good idles low about 500-600 in park, when it warms up it runs worse.
Old August 2nd, 2011, 09:18 PM   #9
Last of the 302's
Road Racing Rookie
Off topic, is that your engine in your avatar?
Back on topic your engine should be around 900 rpm at idle. By any chance did you break one of the tiny wires at the end of the MAF? Check your plug wire also. They could be arcing off onto the headers or any other metal if their old and cracked. This would make the car only run on the cylinders that aren't touching and act erratic.
P.B.M.C. Member
Track Addict
Old August 2nd, 2011, 09:21 PM   #10
91sleeper's Avatar
1991 notch
unplug maf and drive it the car will not idle but if it is the maf it will run like a champ.
-some punk
Old August 2nd, 2011, 09:26 PM   #11
87coupe331's Avatar
avatar motor is in 87 but slightly changed.
MAF wires look good, not broken and plug wires are new and on all the way.
just check out earlier. just puzzled.
Old August 2nd, 2011, 09:28 PM   #12
87coupe331's Avatar
unpluged MAF about a month ago and did not change
Old August 2nd, 2011, 09:32 PM   #13
87coupe331's Avatar
also have problems with motor in the 87, have to set the timming at about 40 deg
to run pretty good
Old August 3rd, 2011, 02:43 AM   #14
1995 Mustang GT Convert.
FAIL@PWR
NFChaos2003 is on a distinguished road
Sounds like a problem I had with my old Camaro where, it would start up, idle, and then gas and it would just sputter and die. Turned out to be the distributor, give it shot cause from what you've said it sounds pretty similar.
Old August 3rd, 2011, 08:56 PM   #15
87coupe331's Avatar
one thing that I forgot is that when I take out the spout to time it, the timming mark is still fluxuating a few deg on either side of the pointer
Old August 4th, 2011, 11:26 AM   #16
Bullitt95's Avatar
13.546 @ 105.32
Interesting. Sounds like the outer ring of the harmonic balancer is slipping on the inner ring. Check the balancer and see if there's any rubber protruding out between the two rings. You might need to replace the balancer to get the timing right.
Old August 4th, 2011, 12:54 PM   #17
95project is on a distinguished road
Did u use the 94 ECU on your new motor?
95 GT- AFR 185's, Comp CAM, Trick FLow TH upper and lower, 30lb injec, 76MM C&L kit, Full MSD, BBK Pulleys, 3:73, BBK Long Tubes, X Pipe, Magnaflow Cat back, Cobra front control arms, MM CC plates LCA's and Panhard bar, tuned by Adam @ Pops Racing.
Old August 4th, 2011, 04:00 PM   #18
95opal's Avatar
95 opalfrost gt
95opal will become famous soon enough
With the spout out the timing should be locked with no fluxuation, if its fluxuating, then I would have to look into what Bullitt said.. possible bad balancer. When you pulled the plugs how do they look and what exactly are you setting the timing to?
5.0 magazines
94-04 performance mustangs feature car! Fall 2010
Old August 4th, 2011, 05:20 PM   #19
87coupe331's Avatar
I have a new balancer and the old one still looks good
it still has the 94 ECU in it
plugs look good, and trying to set timming at 10-14 deg but does not work out.
Old August 11th, 2011, 06:55 PM   #20
87coupe331's Avatar
Got that problem fixed with a new ignition system,
now just need to set the idle,
it idles at about 650-700 in park, way 2 low,
should be there in drive.
