94 GT
13.95@100
![]() iTrader: 2 reviews
No sound from speakers
Hey all,
when I got my mustang it didn't have a radio and the sub-harness was all hacked up. So I found a v6 mustang at the junkyard same year with the stock radio in it and the slave CD player. Took the harness, both parts to the radio, and the computer box under it just in case. Everything plugged right in and it lights up, plays CDs and everything but I don't get any sound from the speakers. I read something about an amplifier needing the remote wire spliced to it, but I'm not sure this car has factory amps. What do you think could be my problem? Last edited by furreal302; August 2nd, 2011 at 12:31 AM. |
Last of the 302's
Road Racing Rookie
I think your car does come with a factory amp rite under the head unit. The Mach 460 system just uses more amps and speakers so it makes me think that even the stock regular radio would still use at least one amp.
![]() Victor ( goofyfeet) Oliver P.B.M.C. Member Track Addict |
94 GT
13.95@100
OK that box I swapped out was the amp then, I figured as much. The rear speakers are aftermarket, someone did a nice job of installing them too. Would that be the reason I'm getting no sound? I tried running power to the blue wire at the deck and still got nothing. thinking about bringing it to the expert... I dont want any aftermarket decks I like the factory look.
1999 Mustang
Try this, with the radio pulled out of the dash but still hooked up, try to connect a speaker lead to the wires and then test a speaker. If you are getting a signal right off the radio then you can move down stream of the wiring until you find where it disconnects.
Also, mixing Mach 460 stuff with non Mach 460 stuff can cause problems. ie: the amp you got from the junkyard was part of a mach 460 setup, but your car is not. So the speaker leads will terminate because they are not carried further by the associated wiring of the mach 460 system. I just went through this on my project car. Had a Mach 460 amp under my radio but the rest of the system was premium sound. So the signal that was meant to go to the back amps never made it that far. In a the 460 setup that amp inside the dash is only used to power the door tweeters, the rear amps would power the rest of the system.
![]() 1999 V6 Vert converted to 5.0 EFI with Vortech V2 SQ, Edelbrock Performer intake, BBK shorties, O/R H, Flowmasters, 42lb injectors, 75mm Pro-M with MAFia extender, 255lph fuel pump. SCT tuned 370 rwhp 400 rwtq. |
94 GT
13.95@100
I figured it out - the amp wasn't getting any power. I took the single yellow wire and put it to a power feed, and the radio put out sound like a champ! So I'm going to splice it into the accessory switched wire (yellow/black) and the problem is solved. Maybe somebody else will find this useful. I'm glad I get to keep the factory radio and retain the clean look of the dash.
94 Opal Frost GT ~230k T5 swap, other mods
Threads Similar to: No sound from speakers
| MSD Blaster Coil = Annoying Sound in Speakers | justi88 | 94-95 | 2 | June 4th, 2011 09:52 AM |
| newb alert 01 cobra took out mach sound wtf happen to the door speakers | shriekk | Audio/Video | 5 | May 29th, 2011 12:17 PM |
| surround sound/sound bar for ps3 and x box | G.T. Rags | The Clubhouse | 38 | July 6th, 2010 09:18 PM |
| Sound issue, (sound clip coming later) | dgt_mustang | V6 Mustangs | 5 | April 11th, 2008 05:08 PM |
| Sound Check Your Stock Head Unit And Speakers (Any Ford) | 04DSGV6 | Audio/Video | 3 | November 28th, 2007 07:49 PM |
