Discussing 95 5.0 upgrades in the 94-95 Forum. Hey everyone, wanted to get some of your advice on some upgrades I am interested ...
Old May 17th, 2007, 08:04 PM   #1
95 5.0 upgrades
Hey everyone, wanted to get some of your advice on some upgrades I am interested in. First I am getting a in motor in my car and want to make it sound good. I was thinking new headers but other than that I wasn't sure on brand or type. As looking to lower what type of springs should I be looking for. Any advice would be appricated.
Old May 17th, 2007, 09:35 PM   #2
Make it sound good...: Headers, Mid Pipe & Mufflers
HEADERS: You want to get long tube (I use bbk works fine for me get ceramic not chrome <- usually turns blue)
MID PIPE: You can try Pro Chamber
MUFFLER: Flowmaster 40's series
Lowering,
You can try echibac lowering springs, you can go with 1.5 no more than 2 inch, then you might need some c/c plates.
Other things you might want to do:
Gears: 3.73 for 5 speed for 4.10 for Auto
Upper and Lower Control Arms (preffer tublar)
SubFrame connectors
Strut Brace Bar (if you dont already have one)
I'll leave the rest up to the other guys here to put in their .2 cent.
Giving Away For FREE PM ME.
FREE 351 Block, 90,xxx miles (Non roller block)
FREE 94-98 GT Hood (red)
Old May 17th, 2007, 11:20 PM   #3
too slow
I like the 3.73 gears. Another thing is that year model had a hard time breathing you might go with an after market intake and a CAI.
95 gt H.O. Udp's, Pypes O/r X, flowmaster 40's,CAI, 3.73 gears, C&L 76mm MAF,GT40p's, Shorties, 1.6 rr's,Gt40 manifold, short throw, Back Seat Delete
BOOSTED
Old May 18th, 2007, 07:35 AM   #4
+1 on that aftermarket upper and lower intake, you can go with holley, or get upper and lower intake from an 97 1/2 up explorer 5.0.
once you start modding, there's no stopping... lol ask anyone here.
Old May 18th, 2007, 11:12 AM   #5
95opal's Avatar
95 opalfrost gt
First off come up with a goal for the car and base your decisions off that. Modding once is cheaper than doing it twice. What type off motor is going in stocker? If so, some of the previous suggestions for manifolds are a bit off. Do yourself a favor use the search function to research things you want to know about after you come up with a goal. Slapping a holley intake on a stock headed, geared car will only slow you down. Again research before buying thats the best info I can give ya for now.
<a href=http://www.moddedmustangs.com/forums/signaturepics/sigpic3130_1.gif target=_blank>http://www.moddedmustangs.com/forums...gpic3130_1.gif</a>
Old May 18th, 2007, 11:23 AM   #6
Bullitt95's Avatar
1995 Mustang GT auto
13.46@104.5
Re: 95 5.0 upgrades
Long tube headers, an X-pipe, and a 2.5" dual exhaust with straight-through mufflers would be great on any 5.0 but I suggest you uncork the intake side of the engine first. That's what I did with very good results. The exhaust will be next.
As far as heads/cam/intake go, the choice will depend on what your ultimate goal is going to be. I'm planning TFS Twisted Wedge heads, TFS Stage 1 cam, and Holley Systemax intake later on.
The 3.73 ring and pinion is definitely the best all round choice for an automatic and probably also for a manual. It's a great mod that I highly recommend even on a near stock GT.
Eibach springs would be a very good choice if you want to lower your GT but beware that you'll need to adjust the camber/caster/toe of the front wheels to correct the alignment and reduce bumpsteer, so consider a set of Maximum Motorsports camber/caster plates with the springs. Tubular control arms, K-member, and A-arms with urethane bushings add strength, tighten the handling, and reduce weight.
Old May 19th, 2007, 01:30 AM   #7
I have a set of barely used longtube BBK headers matched with a shorty H pipe...both in great condition..300 plus shipping for both? LMK.im from CA
Old May 19th, 2007, 07:41 AM   #8
To changing the restrictive design of the upper and lower intake (and heads NOT INCLUDED in this statement) on the 94-95 5.0 wont slow him down. I do upper and lower intake the BBK Cai, and feel """ALMOST"" a seat in the pants difference. (with complete exhaust system)
He's currently making stock 215HP, the stock heads can go well about 300 HP (crank) , so increase the air flow, will help him alot with the headers and exhuast system. REGARDLESS, OF WHAT HE PLANS FOR THE CAR, HE CAN NEVER GO WRONG WITH LONG TUBE HEADERS, AND EXHAUST SYSTEM. ALSO THE UPPER INTAKE AND LOWER INTAKE, HE CAN ALWAYS WORK FROM THERE.
You are right though first come up with a goal for the car.
THOUGH, once you start modding, it never stops.. lol
Old May 19th, 2007, 09:04 AM   #9
Bullitt95's Avatar
13.46@104.5
That's partially true. While a high-flowing intake such as the Holley does produce a HP gain at higher rpm, it's likely to produce a midrange torque loss on stock heads simply because that combination will reduce airflow velocity at lower rpm.
You can get up to ~280hp (crank) using the stock HCI without sacrificing torque lower down but once you add a bigger plenum intake with shorter, larger diameter runners, you can get close to 300hp (stock heads and cam) but you'll lose torque lower down. Simply put, the intake has to match the heads and a large diameter runner intake on restrictive stock heads just doesn't work. At the very least you really need to do the intake and heads together. Then it also makes sense to do the cam swap at the same time.
Come up with a plan and then you'll only need to do the mods once.
Threads Similar to: 95 5.0 upgrades
Upgrades For My 94 Redrider 94-95 15 April 12th, 2007 11:19 AM
Upgrades dsavercool V6 Mustangs 69 March 7th, 2007 12:09 PM
Considering some upgrades... Timber 99-04 34 February 7th, 2007 11:00 AM
Next Upgrades FireryDriver 2005+ 47 December 20th, 2006 12:10 AM
What Upgrades Should I Do? SlowStang V6 Mustangs 6 November 9th, 2006 09:03 PM
