95 GT steering rack
Old August 7th, 2011, 02:11 PM   #1
95RED5.0's Avatar
1995 Mustang GT
95RED5.0 is on a distinguished road
95 GT steering rack
Got a question like always. Do the boots in the steering rack hold fluid? Im asking because my rack is leaking from the boot. The boot does have a small hole but if its not supposed to hold fluid I have another issue. It did have p/s fluid which I've read is a big no no. If the seals are bad can I rebuild the rack or do I need a new one?
Old August 7th, 2011, 10:02 PM   #2
johnGT's Avatar
1995 Mustang GT vert
johnGT is an unknown quantity at this point
My passenger side boot is leaking on mine too. Not sure if you could put a new seal in there or not. I have mine zip tied right now
1995 Mustang GT vert: STOCK, AODE (B&M shift kit), 2.73 gears, red leather, 410,000~ miles.
2007 Mustang GT: 4.6, 5-speed, 3.55 gears, black on black. (dads car)
1975 Camaro LT: 305ci, TH-350, weiand intake, 600cfm carb, 3.42 gears.
Old August 7th, 2011, 10:26 PM   #3
95RED5.0's Avatar
1995 Mustang GT
i have 2 pressure clamps on mine but there is a "pin hole" on my drivers side so i keep leaking. need to figure this out soon.
Old August 8th, 2011, 12:37 AM   #4
Mustang Boy's Avatar
1994 Mustang GT
14.582@92.58MPH
Mustang Boy will become famous soon enough
Send a message via AIM to Mustang Boy Send a message via MSN to Mustang Boy Send a message via Yahoo to Mustang Boy
Cool
The boot does not hold fluid and if you have fluid leaking out of the boots you are going to need a new rack, as far as I know there isn't any kit to rebuild your rack so you may have to bite the bullet and get a new rack.
315's Crew
Black and White Crew
Crew Member #2
Old August 8th, 2011, 02:44 PM   #5
johnGT's Avatar
Kinda what I figured. I'm pretty sure something was ran over and hit the rack causing it to leak.
I can hold off for a while I guess. It's not that bad..just drips every now and then and sprays the bottom passenger side in p/s fluid between oil changes. The p/s fluid is hardly affected strangely so I'm not too concerned.
Once I get a carb, radiator, fan/shroud for my camaro, I'm going to park my stang and completely re-do the front end. Ball joints, sway bar bushings, struts, rack & pinion, etc.
Old August 8th, 2011, 03:03 PM   #6
95RED5.0's Avatar
1995 Mustang GT
All that was just done to mine. My rack started leaking after all that was done. Kind of a never ending battle. My leak is bad, completely empty after 2 days. Only thing i have left besides the a/c leak and I need to get a rear set of stock springs.
Old August 8th, 2011, 03:34 PM   #7
johnGT's Avatar
Is it possible that one side is pulled on harder than the other in turns..?
I swear I have a tighter turning radius going left..
is it your passenger side boot that is leaking?
Old August 8th, 2011, 08:33 PM   #8
95RED5.0's Avatar
1995 Mustang GT
Its my drivers side boot but I believe my car turns to the left better also.
Old August 8th, 2011, 08:45 PM   #9
johnGT's Avatar
Interesting.
The rack just seems packed under the front end to me. I think it's completely possible that when you hit a bump while turning, it stresses the ends of it pretty harshly.
Old November 24th, 2011, 08:47 AM   #10
96Mustang5.0 is on a distinguished road
My right boot is also ripped, I don't see any fluid leaking but the boot is wet. Planning on doing the whole suspension at once too.
Threads Similar to: 95 GT steering rack
can i use fox steering rack on my 95? STREET6 5.0 Mustangs 2 March 1st, 2012 07:58 PM
Steering Rack 68coupe Classic Mustangs 1 February 16th, 2009 03:08 AM
F*%#ing Steering Rack...... Flomaster_Knockoff 5.0 Mustangs 10 March 3rd, 2008 06:56 PM
Steering rack.... lwhitetrash88l V6 Mustangs 3 February 17th, 2008 10:10 PM
Will steering rack fit 83 GLX from 86 GT? 83 5.0 5.0 Mustangs 0 October 14th, 2006 09:40 PM
