95' spring help
Old August 8th, 2011, 10:16 PM   #1
2001 mustang gt
xavier7 has a little shameless behaviour in the past
iTrader: -1 reviews
95' spring help
I can't get these suckers back in.. I've tried the clamp thing with no success. Any tips or pointers?
[/SIGPIC]my car sucks
Old August 9th, 2011, 02:25 AM   #2
Hardon Enflooziast
98FireyGT!'s Avatar
'94 GT Vert
Havn't tried...
98FireyGT! is a glorious beacon of light98FireyGT! is a glorious beacon of light98FireyGT! is a glorious beacon of light98FireyGT! is a glorious beacon of light98FireyGT! is a glorious beacon of light
Send a message via MSN to 98FireyGT!
Front or rear? I never did the rear springs on my car...I got termi ones with my IRS.
When I swapped the Termi front suspension on my car I had trouble with the front springs tho...I found the easiest way to do them was to jack the car up high enough so the control arm dangled freely, put two spring compressors on the spring itself, stick it into place and put a jack under the control arm. SLOWLY start jacking the control arm up, the weight of the car itself will compress the spring down far enough so you can get the strut into the tower...bolt it down into place, pull the spring compressors off, and repeat for the other side.
Bridget: 98 Mustang GT - PI Swapped, J-Mod and B&M Shifter...wrapped it around a tree sparing a deer - RIP
Sephie: 94 Mustang GT Vert - Full 03 cobra suspension and brakes, Magnaflow catback, K&N drop in filter, timed at 12*, SS brake lines,
Old August 9th, 2011, 02:30 AM   #3
95RED5.0's Avatar
1995 Mustang GT
95RED5.0 is on a distinguished road
+1^
Old August 9th, 2011, 03:41 AM   #4
2001 mustang gt
iTrader: -1 reviews
Yea man that's wat I been doing but the damn compresers are too big
Old August 9th, 2011, 04:31 AM   #5
Hardon Enflooziast
98FireyGT!'s Avatar
'94 GT Vert
Havn't tried...
how are they too big? the ones I used you just put on an upper and lower coil, then use the impact wrench to drive the giant bolt through the two halves, pulling them together.
Threads Similar to: 95' spring help
Spring is here! 01stangV6 The Clubhouse 111 March 3rd, 2011 10:49 PM
C Spring- how much to cut? Vapor50Fox 5.0 Mustangs 6 October 31st, 2010 05:06 AM
spring Break from spring break and got troubles ia07gt The Clubhouse 0 March 23rd, 2010 06:57 PM
what spring to go with? 1998_svt_cobra 4V / SVT 9 June 24th, 2008 09:19 PM
Spring kit lwhitetrash88l V6 Mustangs 12 April 24th, 2007 09:44 PM
