AODE Problem!
Old August 9th, 2011, 04:44 PM   #1
94 mustang gt
94mustanggt5.0 is on a distinguished road
Exclamation
AODE Problem!
I just dropped the AODE in my 94 gt. I bought a built AODE with a 3200 stall. I put the new in and started it, put in drive and nothing. The motor will kinda bog and feel like it engages but the car doesn't move. Same as in every drive gear.. Anyone know the problem? Thanks
Old August 9th, 2011, 05:36 PM   #2
johnGT's Avatar
1995 Mustang GT vert
johnGT is an unknown quantity at this point
Sounds like you got a bad stall or installed it incorrectly.
1995 Mustang GT vert: STOCK, AODE (B&M shift kit), 2.73 gears, red leather, 410,000~ miles.
2007 Mustang GT: 4.6, 5-speed, 3.55 gears, black on black. (dads car)
1975 Camaro LT: 305ci, TH-350, weiand intake, 600cfm carb, 3.42 gears.
Old August 10th, 2011, 03:01 AM   #3
Bullitt95's Avatar
1995 Mustang GT auto
13.546 @ 105.32
Bullitt95 will become famous soon enough
As Confucius would say, "Sum Ting Wong".
Sounds like the torque converter was incorrectly installed.
243.5rwhp/284.2rwtq
Mod list in My Garage
Old August 11th, 2011, 01:33 PM   #4
94 mustang gt
i just got a tool to check the pressure in the passenger side port of the tranny to see if the pump is working or not
Old August 13th, 2011, 01:39 PM   #5
99FiveOh's Avatar
1999 Mustang
99FiveOh is on a distinguished road
A really stupid idea, but does it have enough fluid?
1999 V6 Vert converted to 5.0 EFI with Vortech V2 SQ, Edelbrock Performer intake, BBK shorties, O/R H, Flowmasters, 42lb injectors, 75mm Pro-M with MAFia extender, 255lph fuel pump. SCT tuned 370 rwhp 400 rwtq.
Old August 14th, 2011, 03:54 AM   #6
94 mustang gt
i pulled it out again today and swapped valve bodies and made sure the filter wasnt clogged and made sure the stall converter splines werent stripped or anything and that it was installed in the trans and to the flex plate correctly. after installing the transmission again. i still have no forward or reverse gears. its really starting to piss me off. maybe its the pump?
Old August 14th, 2011, 10:19 AM   #7
99FiveOh's Avatar
1999 Mustang
I hate to say it but it sounds like your built AODE wasn't built correctly. I'd be talking to the person/company who built it.
How much fluid are you putting in it? I know it takes a boat load of fluid to fill the converter and everything.
Old August 14th, 2011, 01:04 PM   #8
94 mustang gt
i fill the converter with about a quart before install then after install i fill the tranny before running to desired amount then let it filter while running then top off where it should.. i also need some how-to on how to take out the pump in the tranny because ima swap them and if its not the pump then ive tried everything else and know its the internals.
Old August 14th, 2011, 01:14 PM   #9
99FiveOh's Avatar
1999 Mustang
When you say "built" are you saying you built it or had a shop build it up for you. If it was built up by a shop I'd take it in and make it their problem. I know AODE's are not cheap to beef up so I know if it were me I'd want it working as it should.
Threads Similar to: AODE Problem!
my aode ?????????????? riggsracin 94-95 3 January 12th, 2010 10:12 PM
Aode To T3650 ????? mustang_gtr_99 99-04 30 February 26th, 2009 08:59 AM
Aod-aode-c4 stangage 5.0 Mustangs 3 June 3rd, 2008 09:02 PM
AODE to C4 r7r5 94-95 4 June 25th, 2007 09:37 PM
