Shifter problem
Old August 10th, 2011, 01:44 AM   #1
95RED5.0's Avatar
1995 Mustang GT
95RED5.0 is on a distinguished road
Shifter problem
Converted my car from 5 speed to auto and my shifter sits too high. The bezel will not clip into the console. Any know how to get it to fit properly?
Old August 10th, 2011, 11:13 AM   #2
johnGT's Avatar
1995 Mustang GT vert
johnGT is an unknown quantity at this point
Could you post a pic?
1995 Mustang GT vert: STOCK, AODE (B&M shift kit), 2.73 gears, red leather, 410,000~ miles.
2007 Mustang GT: 4.6, 5-speed, 3.55 gears, black on black. (dads car)
1975 Camaro LT: 305ci, TH-350, weiand intake, 600cfm carb, 3.42 gears.
Old August 10th, 2011, 04:29 PM   #3
95RED5.0's Avatar
1995 Mustang GT
everytime i try it says the file is too big. The bottom of the shifter (the part with the initials p,r,n etc) sits about an inch higher tham the center console.
Old August 10th, 2011, 04:46 PM   #4
johnGT's Avatar
You can upload it at tinypic.com without having to sign up or anything and post a link from there.
Is it just the letter part or the actual shifter itself?
If its just the letter part, it goes under the other console parts. As in, there's no way to fit it right without tearing down the bottom dash and center console.
If it is the actual shifter part that is causing this, well, idk what to tell you. Does the T-5 and the AODE use different trans mounting bars??
Old August 10th, 2011, 06:45 PM   #5
95RED5.0's Avatar
1995 Mustang GT
I got together with another guy that wanted to convert his to 5 speed so we swapped everything. I just dont know whether to beat in where the shifter mounts or what.
Old August 13th, 2011, 04:28 PM   #6
95RED5.0's Avatar
1995 Mustang GT
Anybody please help.
Old August 17th, 2011, 06:33 PM   #7
Jtbacks is on a distinguished road
can you put it into all the selections? (P - 1st ) if so just take that plastic thing off, and put a leather boot, unless you REALLY need the plastic cover.
Old August 17th, 2011, 09:44 PM   #8
95RED5.0's Avatar
1995 Mustang GT
I dont really need it but I would like it to look original.
Old August 17th, 2011, 11:03 PM   #9
Hmm.. did it get knocked a few times, because maybe it's just bent?
Old August 18th, 2011, 12:15 AM   #10
hotmustang95's Avatar
Last of the 302's
Road Racing Rookie
hotmustang95 is on a distinguished road
Could it have something to do with the cross member. Is the 5 speed cross member the same as the auto? Could it be pushing the tranny upward? Don't know if there's a difference between the 2 but if there is then I'm sure that's what's going on.
Victor ( goofyfeet) Oliver
P.B.M.C. Member
Track Addict
Old August 18th, 2011, 11:44 AM   #11
95RED5.0's Avatar
1995 Mustang GT
We swapped cross members also. The shifter is bolted in and thats where it sits.
Old August 18th, 2011, 03:34 PM   #12
Have you considered taking out the shifter? and just seeing if something was wrong. I've never done a 5speed to Auto swap.. soo these are just guesses.
Threads Similar to: Shifter problem
Problem with b&m shifter Hammer 93Coupe50 5.0 Mustangs 3 August 17th, 2010 07:00 PM
shifter problem tutman900 5.0 Mustangs 7 September 29th, 2009 06:15 PM
tranny/shifter problem DeMello 99-04 14 September 8th, 2008 05:02 PM
MGW Shifter Problem hardhitter 99-04 19 November 23rd, 2007 08:57 PM
Shifter Problem Mach Boy 99-04 14 November 2nd, 2007 12:24 AM
