Brakes - Overusing My Rears?
Now, this just happened last night, I have a mean "grinding" coming from my right rear brake assembly. There's now some lines showing up on my rotor, probably being caused by a bad pad or what-have-you. Though, wait... Thought about it...
Could I be overusing my rear brakes? I had posted earlier about doing the BAER swap for the front, and we know those calipers are dual piston. The Cobra in this body style, which has this brake set-up stock, has a hydraboost system. I do not (GT). So, in theory, (correct me if I'm wrong), could I be under working my front brakes, leading me to over use my rear brakes, using them up quicker??
Ok, so none of this was relevant. I had no choice but to take it in and found out my calipers were frozen closed. Check this picture out...
![]() Melted that brake pad like a boss!! What you see behind is the rotor, eaten alive. Now, how did I not see this? Cuz this was the inboard pad. Fml...
Looks like it is time for some new calipers, rotors, and pads.
315's Crew Black and White Crew Crew Member #2
Threads Similar to: Brakes - Overusing My Rears?
| Which are the rears?....... | BakerFX4 | 99-04 | 9 | March 8th, 2011 11:06 AM |
| Any idea how to tint rears like this?!? | Spurred Snake | Visual | 41 | December 20th, 2010 12:20 AM |
| Used rears? | AndrewA. | 99-04 | 7 | May 24th, 2010 08:09 PM |
| How Do I Know If My Rears Got The Gears? | show95stang | 94-95 | 15 | December 17th, 2007 11:16 PM |
| Rears are done! | Ole Yeller | V6 Mustangs | 5 | July 9th, 2007 07:32 AM |
