Just got a new 5.0 and would like some advice
Old August 19th, 2011, 05:55 AM   #1
Romanx is on a distinguished road
Hey guys just got my first 5.0, Unlike most other new mustang owners who only know how to make it faster, my questions are a bit different. It is a 1995 with 80k miles on it. My question is what should i do maitenance wise to ensure that there are no problems around the corner. The car is pretty clean except for a whine from the transmission while i am in third gear and my mileage counter just stopped working all of a sudden. Any help would be great.
Old August 19th, 2011, 08:49 AM   #2
Bullitt95's Avatar
1995 Mustang GT auto
13.546 @ 105.32
Bullitt95 will become famous soon enough
Firstly, it seems that your odometer gears in the back of the intrument cluster are stripped (a common problem) so replace them with a new drive/worm gear from Late Model Restoration Supply. A cheap and easy fix.
The whining in 3rd gear could be a sign that the 3rd gear bearings inside the tranny are worn. The only cure would be to have the tranny rebuilt but you could just change the tranny fluid (ATF) and live with it for a while.
Everything else is just routine stuff you'd do on any car. Check for other fluid leaks, replace any fluids that look old and contaminated, and replace any rubber hoses that are cracked or hardened. Also replace any old filters (air, oil, fuel), check (and if necessary replace) spark plugs, plug wires, distributor cap, and rotor.
243.5rwhp/284.2rwtq
Mod list in My Garage
Old August 19th, 2011, 03:44 PM   #3
94 GT
13.95@100
furreal302 is on a distinguished road
Depending on how loud it is that whine could be regular gear noise. Or just a bearing like Bullitt mentioned. Either way I wouldn't worry too much about it unless it starts getting louder. I've had cars do the same exact thing and put many trouble free miles on them.
94 Opal Frost GT ~230k
T5 swap, other mods
Old August 20th, 2011, 02:43 AM   #4
The whine is pretty noticeable but it does not seems to be affecting performance or anything. How much does it ususaly run for a tranny rebuild? Other than that is seems to run great. I have already decided to get some new brake pads, slotted rotors, tires and shocks this week.
Threads Similar to: Just got a new 5.0 and would like some advice
Tummy Pudge on GF.. need some advice .. Female advice as well!! Dolbs4082 The Clubhouse 35 January 1st, 2012 11:47 PM
advice for a v1 si, need advice quick faon 99-04 3 June 7th, 2011 09:53 AM
New Looking For Advice ZWilson07 96-98 16 November 10th, 2010 02:27 PM
