1995, gt
Odometer and Speedometer off
So I had 3.73 gears put in and now my speedo is off. I put the correct Speedo gear in but it is still off by about 10mph when I'm on the highway and about 4 mph around the city. It is also causing the mileage on my car to go up more than they should.
Does anyone know what I can do to get everything working right? or should i get the speedo gear for like 4.11 gears and jsut deal with it? That way my mileage wont go up as fast. Does anyone know what the RPMS should be around at 75 for a 95 gt with 3.73's?
95 gt- 3.73 gears, cai, 75 mm throttle body, bbk o/r x-pipe, magnaflow muffler and tailpipes, steeda tri-ax shifter, 17" cobra r rims. |
did you install both gears the one inside the transmission and the speedo sender gear should be a yellow gear on the output shaft and a red one on the sender i believe. the previous owner of my car had put just the red gear in and it was off by 10 mph
#3 | |
![]() 243.5rwhp/284.2rwtq Mod list in My Garage |
1995, gt
and is putting the drive gear in the tranny hard? or is it the same general place and ease of installation as the speedo gear? cause the speedo gear was really easy
Not hard but it's more involved. You need to disconnect the driveshaft and remove the tailshaft housing from the tranny to expose the tailshaft. Probably about 1-1/2 hour's work if you put the car on a lift, longer if you're crawling on your back and using jackstands.
Threads Similar to: Odometer and Speedometer off
| speedometer and odometer problem????? vss? | tommyboy2008 | 99-04 | 8 | March 5th, 2011 11:01 PM |
| Odometer and speedometer moody. | 96SNAKE | 4V / SVT | 5 | January 16th, 2010 08:08 AM |
| Odometer!! | 97mustanggt | Audio/Video | 9 | December 19th, 2008 02:51 AM |
| Odometer/Speedometer Question | Eagle2000GT | 99-04 | 1 | December 7th, 2007 08:16 AM |
| Odometer help please! | militant54 | Audio/Video | 10 | August 18th, 2007 03:24 PM |
