Code trouble
Old August 31st, 2011, 12:09 PM   #1
Dixon'sGT is on a distinguished road
Code trouble
I'm new to this OBDI translation. I have a 95 GT that seems to run rich and lacks power. I ran KOER and KOEO tests as well as a balance test. Balance passed, KOER passed. I got codes 113 and 212 from the KOEO test. At least, thats how I interpret them. I counted the flashes between breaks and got 1,1,3, break 2,1,2. I DID unplug the ACT or IAT sensor last night and run it unplugged. CEL on until plugged in again. It runs like the timing is off. Has new plugs, wires, cap and rotor, air filter, fuel filter, etc. I was thinking of replacing the ACT, but have a feeling it may be the ECM or ICM not working here. Any input for the new guy?
Old August 31st, 2011, 04:31 PM   #2
94bossgt's Avatar
94 mustang gt
too slow to tell
94bossgt is on a distinguished road
first of all those codes arent right i looked them up they dont exist need to get it scanned to get the right num but try and clean your maf sensor or unplugging it and se if it runs mine was doing the same thing it was a shotty maf sensor
Old August 31st, 2011, 04:33 PM   #3
94bossgt's Avatar
94 mustang gt
too slow to tell
scratch that comp was being dumb here is 212 diag KEEP ALIVE MEMORY AND ADAPTIVE STRATEGY
The EEC-IV system constantly monitors and adjusts the PCM calibration to correct for normal wear and aging of components. The PCM uses these calibration adjustments to shift fuel delivery calculations and idle speed specifications to compensate for the aging of the vehicle.
When an Electronic Engine Controls (EEC) system component is replaced, the Keep Alive Memory (KAM) should be cleared to erase the information stored by the processor from the original component.
CLEARING KEEP ALIVE MEMORY
To clear the KAM, disconnect the battery negative terminal for five minutes or more (preferably 15 minutes).
ADAPTIVE STRATEGY RELEARN PROCEDURE
After repairs have been made and the KAM cleared drive the the vehicle for at least ten miles to allow the PCM to relearn the values for optimum performance.
NOTE: During the ten mile relearn drive, the vehicle may exhibit some driveability symptoms. These should be eliminated when the KAM has relearned the operating values.
Old August 31st, 2011, 04:36 PM   #4
94bossgt's Avatar
94 mustang gt
too slow to tell
for 113 replace the sensor and disconnect the battery for ten mins again to reset everything
Old August 31st, 2011, 09:39 PM   #5
I thought it only threw that code because i unplugged it for awhile.
Old September 2nd, 2011, 12:54 AM   #6
All research I've done says code 212 is a spout connector issue. Anyone steer me in the right direction?
Threads Similar to: Code trouble
help with trouble code... cubestang04 V6 Mustangs 9 August 16th, 2010 08:59 AM
Ever Had THis Trouble Code? TheUNZippee! 2005 - 2010 22 April 29th, 2009 12:48 PM
trouble code 00vabchgt 99-04 5 April 17th, 2007 03:57 PM
Trouble code dezzrat1 94-95 0 April 17th, 2007 08:36 AM
Trouble code help supu80 V6 Mustangs 8 December 30th, 2006 09:10 PM
