new trickflow heads - Forums at Modded Mustangs
post #1 of 12 Old October 10th, 2011, 09:49 AM Thread Starter
new trickflow heads
Just installed the new twisted wedge heads on my 94 gt,( no new cam or intake for budget reasons). Car is running extremely lean, so much so that my tuner told me it would be dangerous to take it to the track this weekend. But besides that the car is putting 235hp to the wheels. Pretty excited about the results considering he told me ill also probably gain about 30 hp once we get it tuned and running right. My next question is....once i have the money should i continue on with cam and intake without all the bolt ons?(ie TB, MAFS, headers, injectors and fuel pump) or would it be more beneficial to get the bolt ons and THEN the cam/intake? Thanks for the help!
94Beast is offline
post #2 of 12 Old October 10th, 2011, 12:42 PM
MANZO MUSTANG's Avatar
I say figure out your cam intake combo and then add the supporting mods later.
1994 Ford Mustang GT, 306CHP(260rwhp)
Auto,MM Full Length SFC, otherwise stock suspension.
MANZO MUSTANG is offline
post #3 of 12 Old October 11th, 2011, 02:24 AM
I would do the injectors and MAF so that you can at least enjoy what you have. Throwing more parts at it is only going to make your lean condition worse. No sense in adding more performance parts that you can't fully enjoy IMHO.
Sent from my Autoguide iPhone app
______________
Mods:
Paxton Novi 2000 @10psi
3.73 gears
255lph fuel pump
Lucas 42# injectors
Trick Flow 75mm upper intake
Trick Flow 75mm throttle body
Diablo "MAFia"
Dyno tuned by Force Fed performance Sacramento Ca
96paxtonstang is offline
post #4 of 12 Old October 11th, 2011, 02:27 AM
That Regular Guy
TerminalIntelligence's Avatar
I say, do a track heat intake with injectors, bugger MAF and TB, and a tune.
Originally Posted by 4.6DreameR View Post
I would hit it like the fist of an angry God!
Originally Posted by cotton View Post
just wasted my whole night on this thread
Originally Posted by HurrycaneStang View Post
Wait till you waste your entire life on this forum...
2.8 pulley, steeda air filter, aermotive fuel rail, steeda tri-ax, and borla stingers.
TerminalIntelligence is offline
post #5 of 12 Old October 11th, 2011, 05:09 AM
Resident Headbanger
Bullitt95's Avatar
You should be getting a lot more than 235rwhp with TFS heads. Which intake are you using (I presume you have the stock cam)?
Any time you upgrade the heads/intake, you'll find that the stock fuel pump and injectors are inadequate so you really need to upgrade those items either before the heads/intake or at the same time.
2006 GT Deluxe - 5MT - 12.67 @ 108.61
310rwhp 328rwtq with simple bolt-ons
Bullitt95 is offline
post #6 of 12 Old October 11th, 2011, 01:44 PM
Mustang Boy's Avatar
Send a message via AIM to Mustang Boy Send a message via MSN to Mustang Boy Send a message via Yahoo to Mustang Boy
Cool
From what I understood from his post he is running stock intake and came with the TFS heads.
315's Crew
Black and White Crew
Crew Member #2
Mustang Boy is offline
post #7 of 12 Old October 11th, 2011, 02:33 PM
Resident Headbanger
Bullitt95's Avatar
That would be like giving the engine bigger lungs and making it breathe through a straw.
post #8 of 12 Old October 11th, 2011, 02:41 PM
That Regular Guy
I woulda done, heads, intake, injectors, MAF, and fuel pump all at the same time.
post #9 of 12 Old October 11th, 2011, 08:18 PM
fogged306's Avatar
You need injectors and a MAF or a tune before anything. Your tuner is right, if you're running those heads with 19lb injectors, you're asking for trouble. While you're at it a 255lph pump is almost just as mandatory. No you don't actually need one as large as a 255, but they cost nearly the same and you might as well leave room for improvement if you're buying upgraded parts.
fogged306 is offline
post #10 of 12 Old October 13th, 2011, 01:34 PM Thread Starter
Thanks for the advice, and I kno I should've done it all together but I just dont have the money, but I got it it tuned and I'm at 250 rwhp.
94Beast is offline
post #11 of 12 Old October 17th, 2011, 09:56 AM
Gregg@TrickFlow's Avatar
Spot on advice!!! You need to do what this man is suggesting.
Gregg@TrickFlow is offline
post #12 of 12 Old October 17th, 2011, 10:31 AM
No slouch at 250rwhp.
Human Verification
