Vacuum Lines
Old November 1st, 2011, 06:52 PM   #1
Dennzden's Avatar
1995 Mustang GT
Dennzden is on a distinguished road
Vacuum Lines
I was wondering what these are and where they go. I have a 95 5.0. No EGR, Smog pump, or AC. I started to change the top end last year and just now finishing up. Work and kids kinda put everything on hold. I have everything back together except these vacuum lines and timing done.
I think this needs capped but not 100% sure
No idea what this is.
I ran this under the intake to the big port and the pcv to the smaller one under the intake.
What is this and where does it go?
Old November 1st, 2011, 08:18 PM   #2
94 GT
13.95@100
furreal302 is on a distinguished road
That last one, I don't know what it is or what it does. On my GT I have that plugged in but the hose running nowhere.
There are very few vacuum lines that you actually need. If I recollect, you will need the main one going to the brake booster and the PCV valve. From the booster there should be a vacuum block with the lines going to the heater control and cruise. The green one goes to the EGR valve and can be removed completely if running without.
94 Opal Frost GT ~230k
T5 swap, other mods
Old November 2nd, 2011, 05:47 AM   #3
Bullitt95's Avatar
1995 Mustang GT auto
13.546 @ 105.32
Bullitt95 will become famous soon enough
Here's the stock vacuum line diagram:
This is the vacuum line diagram of my car with AC, smog pump, EGR, and cruise control deleted:
243.5rwhp/284.2rwtq
Mod list in My Garage
Old November 2nd, 2011, 10:10 AM   #4
1994 Mustang Cobra
steveofire is on a distinguished road
That last one I believe was part of the egr setup just unplug it and throw it out thats what i did with mine it goes to a box in the passenger side fender wall if you take out your inner you will see the other parts up there that you will no longer use
94 Cobra
351w .040 over
DSS Forged Pistons
Scat Rods
TFTW Heads 2.205 Intake 1.62 Exhaust
Trick Flow R Intake
750Cc RC Injectors
Aeromotive A1000 pump and Reg
Boost Brothers Turbo Kit
Old November 2nd, 2011, 09:45 PM   #5
Dennzden's Avatar
1995 Mustang GT
Thumbs down
Thanks for the diagram and info guys. I have that all done now.
Threads Similar to: Vacuum Lines
Vacuum Lines mustang227 V6 Mustangs 6 October 15th, 2011 10:47 AM
NEED HELP-Vacuum Lines 67svtstang 99-04 7 July 27th, 2010 07:38 PM
vacuum lines ??? worlz08 5.0 Mustangs 1 October 7th, 2008 11:07 PM
vacuum lines terribleonexx88 5.0 Mustangs 2 October 19th, 2006 02:18 PM
vacuum lines 88stang 5.0 Mustangs 11 April 4th, 2006 04:16 PM
