Starts, Runs for awhile, then dies and won't restart
Old November 5th, 2011, 12:39 PM   #1
Dennzden's Avatar
1995 Mustang GT
Dennzden is on a distinguished road
It will start up on the first time everyday then run for 5 mins or so, then it dies and won't start for the rest of the day. I had it running fine last week until i gave it some gas then it all started. I run msd ignition. Has new plugs and wires. Any help would be great.
Old November 5th, 2011, 01:04 PM   #2
1994 Mustang Cobra
steveofire is on a distinguished road
one could be to bypass your msd buy just hooking your coil back up and bypass the msd also take your tfi module off its on the passenger side just infront of the strut tower and take that to a parts store and have it tested
94 Cobra
351w .040 over
DSS Forged Pistons
Scat Rods
TFTW Heads 2.205 Intake 1.62 Exhaust
Trick Flow R Intake
750Cc RC Injectors
Aeromotive A1000 pump and Reg
Boost Brothers Turbo Kit
Old November 5th, 2011, 02:27 PM   #3
Dennzden's Avatar
1995 Mustang GT
Thanks Steve, I will check that out after work.
Old November 6th, 2011, 04:22 PM   #4
Dennzden's Avatar
1995 Mustang GT
Took the TFI to Autozone, passed the test 6 times. I bought some injection cleaner just incase the fuel system is clogged etc. What else could it be?
Old November 6th, 2011, 05:55 PM   #5
fastpony's Avatar
1998 ford mustang gtclone
fastpony is on a distinguished road
Send a message via AIM to fastpony
I would think that you fuel filter got plugged up or something. replace the fuel filter and run some injector clean in the thing. had an issue like this along time ago in my 98 6er.
Old November 6th, 2011, 09:38 PM   #6
MANZO MUSTANG's Avatar
1994 MUSTANG GT
15.15 @ 94.12
MANZO MUSTANG is on a distinguished road
Double check the plugs, makr sure they actually have a gap. I had a buddy who changed them and smasmashed one while installing it.
1994 Ford Mustang GT, 306CHP(260rwhp)
Auto,MM Full Length SFC, otherwise stock suspension.
Old November 6th, 2011, 10:13 PM   #7
Dennzden's Avatar
1995 Mustang GT
I will look at them tomorrow after work. I did recently change em.
Old November 6th, 2011, 10:48 PM   #8
ryanw's Avatar
1991 Ford Mustang GT
run your codes
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old November 7th, 2011, 04:10 PM   #9
Dennzden's Avatar
1995 Mustang GT
No check engine light is coming on when its running. Not sure if that matters.
Old November 7th, 2011, 07:39 PM   #10
fastpony's Avatar
to me it sounds like the fuel filter is clogged. but thats just me...
Old November 7th, 2011, 11:12 PM   #11
ryanw's Avatar
just cuz your check engine light is not on doesnt mean that your computer hasnt stored some codes.
255 fuel pump,
3:27 gears
Old November 8th, 2011, 07:59 PM   #12
Dennzden's Avatar
1995 Mustang GT
Replaced the fuel filter and checked the gap on plugs. I will run the codes tomorrow but problem exists. Could it be because the timing not being set yet or perhaps I didn't install the dizzy right?
Old November 8th, 2011, 08:17 PM   #13
1994 Mustang Cobra
when it dies and doesn't start check for spark and if you have spark then hit the bleeder valve on the fuel rail and make sure you have good fuel pressure
94 Cobra
351w .040 over
DSS Forged Pistons
Scat Rods
Trick Flow R Intake
750Cc RC Injectors
Old November 10th, 2011, 03:09 PM   #14
1994 Mustang Cobra
any updates ?
94 Cobra
351w .040 over
DSS Forged Pistons
Scat Rods
Trick Flow R Intake
750Cc RC Injectors
Old November 10th, 2011, 03:50 PM   #15
fastpony's Avatar
agreed with the fuel pressure regulator
Old November 10th, 2011, 05:30 PM   #16
Dennzden's Avatar
1995 Mustang GT
I haven't had a chance to do anything with work, kids, and prego wife. I will update when I get time.
Old November 10th, 2011, 09:57 PM   #17
MakeFast's Avatar
1995 Mustang GT
MakeFast is on a distinguished road
Make sure you didnt cross any wires, the distributor turns counter-clockwise recheck your firing order on your lower intake manifold to make sure everything is correct.
Old November 12th, 2011, 02:14 PM   #18
Dennzden's Avatar
1995 Mustang GT
Ok just ran the codes.
327 EVP/EPT circuit below minimum voltage
565 Canister purge solenoid circuit fault
10
111 system pass
Old November 12th, 2011, 06:56 PM   #19
Dennzden's Avatar
1995 Mustang GT
Test spark on #1 plug and it has spark. Fuel pressure is around 35 when running. Come to find out they had the msd ignition control bypassed. Hooked it all back up and still won't start. When I bought the car they didn't have the normal firing order set up in the dizzy. I'm confused lol
Threads Similar to: Starts, Runs for awhile, then dies and won't restart
Car starts, then dies. Nightmare 99-04 7 December 25th, 2011 09:04 PM
98 GT starts then dies... Greg98gt 96-98 20 March 5th, 2011 10:13 AM
Amp Issues, Starts and then dies. fbody89 5.0 Mustangs 18 October 26th, 2009 05:08 PM
Starts then dies????? help sniperrider 5.0 Mustangs 3 March 20th, 2009 12:14 AM
Starts and Dies RDR61 5.0 Mustangs 4 July 4th, 2007 10:11 PM
