#21 |
The cold starting issue may be your Coolant Temperature Sensor. On startup the ECU registers your Coolant Temperature Sensor, IAC, MAF, and O2 sensors and based off of those bits of information your ecu sets the timing curve and fuel delivery for warm up. it's a little more complicated than that I know, but once up to operating temps the ecu kicks back to the normal operating tune. the CTS has a tendency to fail and does not send the proper signal to the ecu, you can use a multi-meter to test these sensors as well, but a simple test is unplug it on startup and see if you have a better time starting, if so replace it. Hope this helps
#22 |
1994 Mustang Cobra
on the 94-95 there is a hole on top of the iac that you will be able to put a small allen wrench in there and adjust your idle after the iac is hooked up
94 Cobra 351w .040 over DSS Forged Pistons Scat Rods TFTW Heads 2.205 Intake 1.62 Exhaust Trick Flow R Intake 750Cc RC Injectors Aeromotive A1000 pump and Reg Boost Brothers Turbo Kit
Threads Similar to: New to the SN95
| sn95 kit car??? | hlinar | The Clubhouse | 9 | April 27th, 2011 06:47 PM |
| Fox Vs. sn95 | Mattd76 | 5.0 Mustangs | 26 | March 31st, 2011 11:43 PM |
| m90 on a sn95 gt | riggsracin | 94-95 | 1 | January 26th, 2010 11:14 PM |
| sn95 e fan | chickenbot | 5.0 Mustangs | 10 | February 22nd, 2009 07:48 PM |
