PCv question
Old November 13th, 2011, 01:21 PM   #1
1995 Mustang GT
SpdBoss is on a distinguished road
PCv question
When i pull the line off of the pcv valve, the valve itself has a vacuum on it, and the line from intake has vacuum on it. Now i know the intake should, but should the valve as well?
Old November 13th, 2011, 04:24 PM   #2
johnGT's Avatar
1995 Mustang GT vert
johnGT is an unknown quantity at this point
I'm pretty sure it should. This way oil doesn't get out, but air can get in.
1995 Mustang GT vert: STOCK, AODE (B&M shift kit), 2.73 gears, red leather, 410,000~ miles.
2007 Mustang GT: 4.6, 5-speed, 3.55 gears, black on black. (dads car)
1975 Camaro LT: 305ci, TH-350, weiand intake, 600cfm carb, 3.42 gears.
Old November 13th, 2011, 06:48 PM   #3
1995 Mustang GT
But if the intake is pulling vacuum in one direction an the pcv is pulling. In the opposite direction, hows that gonna work?
Old November 14th, 2011, 12:01 AM   #4
johnGT's Avatar
I think it is all a continuing vacuum internally. It's just when you disconnect the hose, both become a vacuum.
Old November 14th, 2011, 12:44 AM   #5
94 GT
13.95@100
furreal302 is on a distinguished road
The valve closes at low engine vacuum (wide open throttle for instance). During normal driving, idling, and cruising the intake manifold has lots of vacuum and sucks the vapors through the PCV valve. During hard driving the valve closes and blowby gases and oil vapors are sucked out of the valve cover through the air intake. I'm thinking that with the engine idling you should get a little bit of air coming out of the valve. IDK
94 Opal Frost GT ~230k
T5 swap, other mods
Threads Similar to: PCv question
quick question. fuel rail question on mark viii swap Speedy1221 99-04 7 October 12th, 2011 11:02 PM
pro 5.0 shifter question + smog pump elimator bracket question GMcanblowmyFORD 5.0 Mustangs 6 June 28th, 2011 09:29 PM
cam with nitrous question, frpp manifold intake question slater 2005 - 2010 57 November 14th, 2010 05:40 PM
Exhaust question and tuner question.....dont laugh lol Drick 99-04 19 September 24th, 2009 03:42 PM
Muffler question (visual aspect) + Emblem question warrior86 Visual 5 November 20th, 2007 09:55 PM
