86-93 pulley swap
Old November 15th, 2011, 12:18 AM   #1
95Pony is on a distinguished road
86-93 pulley swap
I contacted procharger today about me upgrading from a p-1sc to a d-1cs. I also mentioned that i wanted to run about 16-18lbs of boost, and 8 or 12 rib belt. The guy said that i would have to swap the whole front end of the engine over to 86-93 style pulleys, timing cover, and water pump along with their renegade bracket in order to accomplish this with out belt slippage. My question is, has anyone done this before? Is it some what easy to do?
*wrong area i know*
But since i will be switching to the renegade bracket, and buying bigger injectors i will have those and a calibrated MAF for sale as well. Not sure what a good price on the bracket is, it's barely used. The injectors have about 5-600 miles on them. MAF works great and was bought at the same time as the injectors.
If interested email me at: elphroggo@yahoo.com
sorry for the messed up post.
Dart Iron Eagle block & Pro 1 heads
DSS 347
80lb injectors
D1-SC
blueovalindustries headers
BBK o/r X
Flowmaster cat-back
3.73 gears
Old November 15th, 2011, 02:01 PM   #2
johnGT's Avatar
1995 Mustang GT vert
johnGT is an unknown quantity at this point
The only differences are the water pump pulley and maybe the tensioner. Not really a big deal. I'm not sure if you have to swap anything else though. (timing cover, etc.)
1995 Mustang GT vert: STOCK, AODE (B&M shift kit), 2.73 gears, red leather, 410,000~ miles.
2007 Mustang GT: 4.6, 5-speed, 3.55 gears, black on black. (dads car)
1975 Camaro LT: 305ci, TH-350, weiand intake, 600cfm carb, 3.42 gears.
Old November 16th, 2011, 02:31 PM   #3
Yeah the timing cover is different as well. Both the water pumps are counter-clock wise right? What's the difference in the pulley's?
DSS 347
80lb injectors
D1-SC
BBK o/r X
Flowmaster cat-back
3.73 gears
Old November 16th, 2011, 04:52 PM   #4
johnGT's Avatar
sn95s are counter clockwise. the foxes are clockwise I believe. It's not so much the pulley thats different, its the internals.
Meaning, you can't run a counter clockwise water pump clockwise.
Threads Similar to: 86-93 pulley swap
Pulley swap on 04 Cobra qwkpny9150 4V / SVT 9 September 17th, 2010 06:20 PM
Pulley Swap 2SLO2GO 99-04 0 June 29th, 2010 11:41 AM
pulley swap on an s-trim flattusmaximus78 5.0 Mustangs 41 June 23rd, 2009 10:15 PM
Pulley Swap 2007 GT/CS 2005 - 2010 7 October 7th, 2007 12:54 PM
8 rib pulley swap info sonicblue 99-04 12 September 14th, 2007 10:57 AM
