'94 GT Coupe
Differences between driveshafts
I'm rebuilding my t5 and I want to replace my driveshaft also. There's some marks on it from the brake cable grinding on it (doesn't seem too deep).
I've been given different opinions on aluminum vs carbon fiber shafts and I haven't been lucky on a write up. Can someone explain the differences between the two and which I should buy. Thanks |
98 Cobra
i would assume its all the weight, the carbon drive shaft is gona be lighter than the aluminum. if you have the money i would go with the carbon one. (the new 2013 gt500 will come with one)
Last of the 302's
Road Racing Rookie
I bet those CF one's would cost way too much. Can't go wrong with the tried and true FRPP aluminum shaft for under $300.
![]() Victor ( goofyfeet) Oliver P.B.M.C. Member Track Addict |
'94 GT Coupe
I found a website explaining the differences.
And yes, the first CF shaft I found was $900, HA! With aluminum shafts though, what do I need to look for? |
'94 GT Coupe
Btw guys, thanks for the help.
Last of the 302's
Road Racing Rookie
Just buy yourself a new one like I just did. It comes with new high performance U-joints and the yolk for like $280. Used ones are out there but you wouldn't trust the u-joints and end up getting new ones anyways. With a new one you get everything and no worries.
#7 | |
'94 GT Coupe
Also, I don't know if I've asked you this before or not, but can I see your hood pins with and without the hood locked? |
#8 | |
Last of the 302's
Road Racing Rookie
94 GT
13.95@100
![]() iTrader: 2 reviews
love those headlights
94 Opal Frost GT ~230k T5 swap, other mods
1994 MUSTANG GT
15.15 @ 94.12
![]() iTrader: 1 reviews
Is that a Mach 1chin spoiler? Looks way bigger.
1994 Ford Mustang GT, 306CHP(260rwhp) Auto,MM Full Length SFC, otherwise stock suspension. |
'94 GT Coupe
Last of the 302's
Road Racing Rookie
Boss Shinoda Spoiler
1994 MUSTANG GT
15.15 @ 94.12
'94 GT Coupe
When I removed my transmission this weekend I could not remove the driveshaft. I had to remove the tranny and shaft and the same time and later had to hammer the driveshaft off.
Found a very noticeable groove on the yoke. Long story short. A bunch of bushings and bears are gone due to low oil (Thanks to inexperienced mechanics - not my choice in the first place) and the rear seal and bushing on the transmission were off/gone and caused the groove. Tranny is being rebuilt but in the meantime should I A. replace and yoke and U-Joints OR B. New driveshaft. The stock shaft looks fine but then again it's a reason to replace it. |
98 Cobra
perfect time and reason to pick up a new aluminum one.
Ford Racing 28 Spline Aluminum Mustang Driveshaft (79-95 5.0L, 94-04 V6) at AmericanMuscle - Free Shipping! |
#16 | |
Last of the 302's
Road Racing Rookie
'94 GT Coupe
Trying to save some cash at the moment but...
Aluminum $250-300 VS. Stock (possibly faulty) +U-joints ($10 each) +Yoke ($50-60) ..too bad CF aren't $200! |
Threads Similar to: Differences between driveshafts
| 1pc Driveshafts | RetroGT2006 | 2005 - 2010 | 31 | September 4th, 2010 11:53 PM |
| Driveshafts | thepizzle44 | 99-04 | 14 | July 5th, 2009 08:59 PM |
| Driveshafts | 07stanggt | 2005 - 2010 | 59 | January 22nd, 2009 01:12 PM |
| whats up with the Driveshafts? | leebunnyz | 2005 - 2010 | 13 | July 30th, 2008 11:47 AM |
| Driveshafts | 90mustang50 | 5.0 Mustangs | 33 | December 10th, 2007 10:37 PM |
