More check engine codes.
Old May 30th, 2007, 08:55 AM   #1
lugthug713's Avatar
2002 Roush 360R
lugthug713 is on a distinguished road
On my 95 stang I checked the codes here they are.
Car on but not running
this is the 1st code I got and it was only one time
331-But its not in the book.
all these codes below I got them twice
172-heated O2 sensor indicaiets lean condition, right side
176-heated O2 sensor indicaiets lean condition, left side
332-insufficiant EGR valve opening detected
334-EGR valve postition sensor voltage above closed limit
556-Primary fuel pump circuit failure
Motor running
All these code I got twice
116- Coolent temp sensor out of self test range
136-heated O2 sensor indicaiets lean condition, left side
334-EGR Valve postion sensor voltage above closed limit
Can anyone help with what to do about these codes???
Old May 30th, 2007, 08:35 PM   #2
lugthug713's Avatar
2002 Roush 360R
anyone
Threads Similar to: More check engine codes.
Check Engine Error Codes billb303 5.0 Mustangs 11 July 24th, 2007 12:45 AM
Check engine codes......can anybody help squirt 5.0 Mustangs 0 April 18th, 2007 12:41 AM
Engine Codes terribleonexx88 5.0 Mustangs 10 November 10th, 2006 11:37 AM
Engine codes and ECU problems? wilecoyote 96-98 6 June 9th, 2006 08:02 AM
Please Help! Check Engine codes? 97Cobra 96-98 2 April 5th, 2006 07:20 PM
