Discussing intake question in the 94-95 Forum. i am on a budget right now and i am going to be super charging ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
intake question |
I know you can used from late 1997 and up with the 5.0L , those also get the GT40p heads, I think you might have to go with a different cam, and you'll be good.. upgrade CAI, at at least 70MM TB
FREE & FOR SALE 198x 351W Block - 90,xxx Miles (FREE) 94-98 GT Hood, 2 pr tail light - 1 Pr power mirror - FREE NEW - ENERGY SUSP Motor Mount POLY, RED ($100) NEW - Reserve Glow Blue/Green ($50) |
the explore has gt 40p heads or i need them and what caI |
they explorer already have the heads
what does CAI stand for well i guess i will look for heads and intake of a 98 and newer 5.0 since they are gt40 p heads then maybe i will get them ported and polished are they aluminum or steel and am i wasting time and money if i do this and do the heads bolt right on with all of the smog stuff i called a wrecking yard and they said they needed a number there is 3 different ones
CAI - Cold Air Intake
I think the heads and Iron/Steen not Aluminum. Yes, you can use the Upper and Lower Intake, and the Cly. Heads. You'll need a 70MM Throttle Body, and someone here can recommend a cam for you to use with the heads and intake. Do a complete exhaust system too. if done right you might see about 300hp (Crank) or around 260-275 rear wheel horsepower
if you plan on using a blower or turbo use an E or F cam . the F cam is a has a rougher idle.Both of these cams are from Ford Motorsport and
arent that expensive. The E cam idles a lot smoother and would be more stealth like than the F cam
Speed kills drive an import and live forever. 1991 LX 5.0 H/B 1990 T-BIRD SC |
arent that expensive. The E cam idles a lot smoother and would be more stealth like than the F cam what is the difference between the e or f cam is one make more power at higher boost is one more streetable is there a big power difference between the two[/b] |
the f cam has a rougher idle and will make more power on boost,while the e cam is smoother and should give you better driveability while working well with boost.you should check out Turbomustangs.com for info on turbo kits and is very informative if you want to do a DIY turbo setup
if you wanna savesome money
Threads Similar to: intake question
| intake question | burin_rubber | Engine | 8 | July 30th, 2007 11:11 PM |
| Intake question | scxc15 | V6 Mustangs | 3 | April 12th, 2007 12:26 AM |
| 06 V6 Intake question | Ware | V6 Mustangs | 15 | March 21st, 2007 07:48 PM |
| Intake question? | 00stang | V6 Mustangs | 6 | January 31st, 2007 12:06 AM |
| intake question | speed4goal | 5.0 Mustangs | 3 | January 23rd, 2007 05:37 PM |
