98 Cobra
crankcase pressure
help! check out my thread
crankcase pressuriesed? - Ford Mustang Forums : Corral.net Mustang Forum |
1995 Mustang GT vert
Get a new grommet and screen for the pcv.
1995 Mustang GT vert: STOCK, AODE (B&M shift kit), 2.73 gears, red leather, 410,000~ miles. 2007 Mustang GT: 4.6, 5-speed, 3.55 gears, black on black. (dads car) 1975 Camaro LT: 305ci, TH-350, weiand intake, 600cfm carb, 3.42 gears. |
98 Cobra
ok ill give it a shot. they are cheap enough, i was thinking the same thing, i hope it works
Actually, the more I think about it, why would the pressure be high if there is a leak in the system?
98 Cobra
i was hoping that the high pressure was gona cause the pcv to not be enough to vent the case, but i have a rear main already and none of my damn local shops had a grommet and screen so i dropped the trans today and am gona replace the rear main tomarrow
Leaking or not those gauges aren't very accurate.. Mine actually reads that high with no leaks and normal pressure. A bad PCV grommet or valve won't cause a seal to pop. As johnGT questioned it will actually be less pressurized.
Dart Iron Eagle block & Pro 1 heads DSS 347 80lb injectors D1-SC blueovalindustries headers BBK o/r X Flowmaster cat-back 3.73 gears |
Exactly^.
All my oil leaks have been taken care of and my PCV is fully functional. It sits just a tad lower than the pic he posted. Not a big deal I think. I don't even think the gauge would even tell you if it was really high...It is not an actual "gauge" anyway, it's just an electrical switch. It simply turns it up to around normal if it reads above 6psi.
Threads Similar to: crankcase pressure
| Crankcase evacuation ??? | slo3gt | 99-04 | 4 | December 19th, 2010 02:15 PM |
| crankcase pressure | seans mustang | 5.0 Mustangs | 0 | August 26th, 2010 07:18 PM |
| Crankcase Filter | Robichj | 99-04 | 1 | April 21st, 2010 02:04 PM |
| Dipstick Hits Something In Crankcase | Garman91 | V6 Mustangs | 4 | March 29th, 2009 12:46 PM |
| Seafoam in Crankcase | I_eat_rice | 99-04 | 65 | March 30th, 2008 09:28 PM |
