What To Look Into Regarding Excessive Fuel Consumption - Page 2
Old November 30th, 2011, 05:19 PM   #21
Bullitt95's Avatar
1995 Mustang GT auto
13.546 @ 105.32
Bullitt95 will become famous soon enough
There would have to be one hell of a leak for him to get only 118 miles per tank and I'm sure he'd smell a leak that big.
I'm still leaning towards the original 16 year old O2 sensors being the culprits.
Old November 30th, 2011, 06:37 PM   #22
ryanw's Avatar
1991 Ford Mustang GT
Hey since were all giving our miles per gallon , I'm getting 13-14 mpg
I hope that helps th op out.....lmfao j/k
Ya I'd replace the o2s
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old November 30th, 2011, 08:45 PM   #23
Dan_T_Mustang's Avatar
1995 Mustang GT
Dan_T_Mustang is on a distinguished road
I just noticed today that my tempurature gauge takes REALLY long after I start driving to move up a bit into the "normal" part of the gauge, and even after that it doesn't go up as much as it use to, am I right to suspect my thermostat is stuck open? That could be a culprit for fuel economy as well correct? But I'm planning to do 02 sensors soon too, doesn't hurt. And the fuel injector cleaner someone mentioned.
Hurst Billet/Plus SST Short Throw Shifter, 1999 SVT Cobra Wheels, BBK O/R H-Pipe, Flowmaster American Thunder Catback Exhaust System, 5% Window Tint On Back 3 Windows, Eibach Pro-Kit Lowering Springs, Eibach 1" Wheel Spacers, BBK Cold Air Intake.
Old November 30th, 2011, 09:33 PM   #24
MANZO MUSTANG's Avatar
1994 MUSTANG GT
15.15 @ 94.12
MANZO MUSTANG is on a distinguished road
I averaged 14.5 on 13.5 gallons of 91 octane.
1994 Ford Mustang GT, 306CHP(260rwhp)
Auto,MM Full Length SFC, otherwise stock suspension.
Old December 1st, 2011, 03:36 AM   #25
dcam503's Avatar
SN95GT
dcam503 is on a distinguished road
wow you guys are funny, glad to entertain. I'm sorry my car skillz are so rusty, i have been riding sportbikes for years and forgot about all the different electronics and parts to a car motor. that being said, i don't know what your issue is. bullit has a point about the leak, i just say that because i have personally had it happen to me with my 99 stang. replace that sensor and see if that works. i didn't realise these had such bad mpg to begin with so thats why i was stating mine.
Old December 1st, 2011, 09:40 AM   #26
Bullitt95's Avatar
13.546 @ 105.32
Not really. Don't forget it's winter now so the engine will take longer to warm up and it's likely the gauge readings will stay lower too. That's normal. If you want your engine to warm up faster, you could try blocking off part of the grill with silver foil.
Since everyone else is having a "mpg party" I'm also going to join in; 15-16mpg city and 20-21mpg highway (75mph).
Old December 1st, 2011, 11:47 AM   #27
95project is on a distinguished road
If i get 12 mpg in mine i would feel pretty damn proud...bet im closer to 10...but who gives a shit, its a mustang. they were not designed for good mileage unless you go with the V6. They made the v6 for girls and for people who want to buy the most pointless combination of engine and car ever made (I'll withdraw this point for the 2012 , 305 HP v6 i guess...).
2 things you almost HAVE to accept when you start modding, crappier gas mileage, and more emissions...its just how it is. Anything over 12mpg i consider good for a 15+ year old sports car.
95 GT- AFR 185's, Comp CAM, Trick FLow TH upper and lower, 30lb injec, 76MM C&L kit, Full MSD, BBK Pulleys, 3:73, BBK Long Tubes, X Pipe, Magnaflow Cat back, Cobra front control arms, MM CC plates LCA's and Panhard bar, tuned by Adam @ Pops Racing.
Threads Similar to: What To Look Into Regarding Excessive Fuel Consumption
Any tips on home air conditioning power consumption savings? asiansensation78 The Clubhouse 23 May 7th, 2010 01:17 PM
cams and oil consumption garydahl 2005 - 2010 2 April 19th, 2010 05:20 PM
Possible Fuel consumption problem jgibby 2005 - 2010 8 August 13th, 2009 07:04 AM
Excessive Heat Dallas01GT 99-04 14 July 30th, 2007 12:43 AM
oil consumption cali 5.0 5.0 Mustangs 35 August 8th, 2006 01:52 PM
