What To Look Into Regarding Excessive Fuel Consumption
Old November 27th, 2011, 07:15 PM   #1
Dan_T_Mustang's Avatar
1995 Mustang GT
Dan_T_Mustang is on a distinguished road
So I'm trying to get my 1995 Mustang GT to be a bit better on gas cause it should be A LOT better.
Things I've done so far:
- Clean MAF
- Spark Plugs
- Wires
- Fuel Filter
- Cap And Rotor
Question is what else could be causing the car to spend too much gas? I'm thinking of looking into the 02 sensors next. Lastly I don't drive it hard at all, and I'm shifting at 2000rpm's.
Hurst Billet/Plus SST Short Throw Shifter, 1999 SVT Cobra Wheels, BBK O/R H-Pipe, Flowmaster American Thunder Catback Exhaust System, 5% Window Tint On Back 3 Windows, Eibach Pro-Kit Lowering Springs, Eibach 1" Wheel Spacers, BBK Cold Air Intake.
Old November 27th, 2011, 07:46 PM   #2
94 GT
13.95@100
furreal302 is on a distinguished road
does the exhaust smell rich at all? check for air/vacuum leaks
94 Opal Frost GT ~230k
T5 swap, other mods
Old November 27th, 2011, 07:55 PM   #3
1995 Mustang GT
No it doesn't.
Old November 27th, 2011, 08:21 PM   #4
1995 Mustang GT
I'm really leaning towards the 02 sensors right now, anyone have any insight on how much of a difference these would do to your fuel economy?
Old November 27th, 2011, 10:49 PM   #5
johnGT's Avatar
1995 Mustang GT vert
johnGT is an unknown quantity at this point
I was just about to suggest those. They can have a PROFOUND affect on your fuel economy.
1995 Mustang GT vert: STOCK, AODE (B&M shift kit), 2.73 gears, red leather, 410,000~ miles.
2007 Mustang GT: 4.6, 5-speed, 3.55 gears, black on black. (dads car)
1975 Camaro LT: 305ci, TH-350, weiand intake, 600cfm carb, 3.42 gears.
Old November 27th, 2011, 11:01 PM   #6
ryanw's Avatar
1991 Ford Mustang GT
do you still have your EGR ?
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old November 27th, 2011, 11:20 PM   #7
95Slobra's Avatar
1995 Mustang Gt
95Slobra is on a distinguished road
mine sucks ALOT..and also smells up the garage..sucks
95' GT, Trickflow setup, Aluminum heads with 1:6 roller rockers, e303 cam, BBK shorties into Magnaflow exhaust, BBK cold air intake with 75maf, Highperformance waterpump w/ electric fans
Old November 27th, 2011, 11:49 PM   #8
Mustang Boy's Avatar
1994 Mustang GT
14.582@92.58MPH
Mustang Boy will become famous soon enough
Send a message via AIM to Mustang Boy Send a message via MSN to Mustang Boy Send a message via Yahoo to Mustang Boy
Cool
First question that should be asked is what kind of gas mileage are you getting? And how are you measuring your gas mileage.
315's Crew
Black and White Crew
Crew Member #2
Old November 28th, 2011, 12:17 AM   #9
dcam503's Avatar
SN95GT
dcam503 is on a distinguished road
I'm having the same issue, interested in what mpg your getting and if your driving in the city or highways? i drive 70 miles round trip daily and get around 20 mpg/ 7 miles to the hwy from home.
Old November 28th, 2011, 12:59 AM   #10
Bullitt95's Avatar
1995 Mustang GT auto
13.546 @ 105.32
Bullitt95 will become famous soon enough
Depends on the condition of the existing O2 sensors. If they're ready for retirement, new sensors will make a big difference.
243.5rwhp/284.2rwtq
Mod list in My Garage
Old November 28th, 2011, 03:30 PM   #11
johnGT's Avatar
20mpg sounds pretty accurate. What kind of mods are you running?
Old November 29th, 2011, 01:48 AM   #12
1995 Mustang GT
I'm getting only about 118 miles for a FULL tank of gas, 02 sensors are still the factory ones I believe, and most of my driving is a good mix of city and highway.
And yes I still have my EGR.
Old November 29th, 2011, 03:10 AM   #13
1994 Mustang GT
14.582@92.58MPH
Cool
Do you have a CEL on? How aggressively do you drive?
I ask the second because when I first got my 94 I drove it like a madman and only got 12mpg(90% city). Now that I had laid off and relaxed I was able to average 21mpg on the highway and that is with 3.73 gears.
315's Crew
Crew Member #2
Old November 29th, 2011, 09:37 AM   #14
johnGT's Avatar
My o2 sensors are factory as well . Either I'm really fortunate or just arrogant (my gas mileage doesn't vary much though).
As soon as it starts getting bad though, I'm replacing the o2's ASAP.
Old November 29th, 2011, 10:25 AM   #15
Bullitt95's Avatar
13.546 @ 105.32
Then I suggest you replace your O2 sensors. Worst case scenario your mpg won't improve and you'll have two good O2 sensors as spares.
243.5rwhp/284.2rwtq
Old November 29th, 2011, 05:54 PM   #16
95project is on a distinguished road
Holy crap...thats bad...Check your O2's for sure...
95 GT- AFR 185's, Comp CAM, Trick FLow TH upper and lower, 30lb injec, 76MM C&L kit, Full MSD, BBK Pulleys, 3:73, BBK Long Tubes, X Pipe, Magnaflow Cat back, Cobra front control arms, MM CC plates LCA's and Panhard bar, tuned by Adam @ Pops Racing.
Old November 29th, 2011, 09:43 PM   #17
1995 Mustang GT
I do but I got it scanned and it showed up as a coolant tempurature sensor code but I changed it to a new one and it still comes on. And I don't drive agressively at all on my daily commutes since I daily drive my car.
Thanks for all the replies guys, I'll probably change out the 02 sensors asap. I'll let you guys know what difference they make if any.
Old November 30th, 2011, 12:46 AM   #18
dcam503's Avatar
SN95GT
actually i just realzed i was dking my math wrong. i put 6 gal in and get 110 miles making it about 18mpg.. I'm not driving it hard, got exhaust, cai, msd ignition. what's this I'm reading about removing the egr? and i use plus.. only fill it once a month bit pretty much always keep it above quarter if that matters
Old November 30th, 2011, 06:32 AM   #19
Bullitt95's Avatar
13.546 @ 105.32
actually i just realized i was dking my math wrong. i put 6 gal in and get 110 miles making it about 18mpg..
OK, so you're getting 18mpg instead of 20 which still isn't bad. That does diddly squat to help the OP with his problem.
243.5rwhp/284.2rwtq
Old November 30th, 2011, 12:19 PM   #20
dcam503's Avatar
SN95GT
no shit, i was stating i was getting shitty mpg to and wanted to know what was doing it for him. someone asked what mods i had, just answering. don't get your panties all bunched up. and while i may be getting decent mpg, i should be getting better.
op, have you tried fuel system cleaner? it wont do anything big but i got about 2mpg out of it with my last stang. also, im pretty sure you have a leak in you line somewhere.. have you followed your fuel line back to your fuel filter?
Threads Similar to: What To Look Into Regarding Excessive Fuel Consumption
Any tips on home air conditioning power consumption savings? asiansensation78 The Clubhouse 23 May 7th, 2010 01:17 PM
cams and oil consumption garydahl 2005 - 2010 2 April 19th, 2010 05:20 PM
Possible Fuel consumption problem jgibby 2005 - 2010 8 August 13th, 2009 07:04 AM
Excessive Heat Dallas01GT 99-04 14 July 30th, 2007 12:43 AM
oil consumption cali 5.0 5.0 Mustangs 35 August 8th, 2006 01:52 PM
