Supercharging
Old December 1st, 2011, 06:07 PM   #1
SCHROEDTER's Avatar
99 Vortech GT
SCHROEDTER is on a distinguished road
Supercharging
I have a 94 gt and I'm wanting to put a self contained vortech supercharger and want to run 6-8 psi. I was wondering what size injectors I should run or if I would even have to change them and if I have to upgrade the fuel pump or mass air if I get it professional tuned.
Old December 1st, 2011, 07:24 PM   #2
95project is on a distinguished road
It will depend on what mods you already have as to how big your injectors will need to be. Stock motor running 6-8 psi could probably get by with 24's. 30's would be safe also. You will have to get a tune when you get bigger injectors and a bigger MAF. You may also need to get a bigger fuel pump. My motor was making about 350 FWHP and was running out of fuel around 4,800 RPM. Mass air will have to be calibrated for whatever size injectors you go with. You will definitely need a tune though.
95 GT- AFR 185's, Comp CAM, Trick FLow TH upper and lower, 30lb injec, 76MM C&L kit, Full MSD, BBK Pulleys, 3:73, BBK Long Tubes, X Pipe, Magnaflow Cat back, Cobra front control arms, MM CC plates LCA's and Panhard bar, tuned by Adam @ Pops Racing.
Old December 1st, 2011, 10:01 PM   #3
ryanw's Avatar
1991 Ford Mustang GT
24lb are to small to supercharge, 24lb are good when you do just an hci combo.
Just go with 42lb to be safe and have the car tuned, you may be able to get away with 36lb injectors,(30lb at the minimum but i bet there wont be much left to turn the boost up)
but by going with the larger injectors and fuel pump gives you room to grow and you wont end up buying the same parts twice.,A bigger fuel pump is a must have item, 255lph
make sure the car gets tuned,
dont run a FMU with under sized injectors or youll regret it
If the car is tuned you dont need to get a new maff (thats if your running the stock maff) cuz they can tune the new size injectors into the computers program, if you choose not to get it tuned youll need to get a new maff calibrated to the new injectors. or some sort of hand held tuner and do it your self
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old December 2nd, 2011, 03:09 AM   #4
Bullitt95's Avatar
1995 Mustang GT auto
13.546 @ 105.32
Bullitt95 will become famous soon enough
Agree with everything ryanw said. Very good advice.
243.5rwhp/284.2rwtq
Mod list in My Garage
Old December 2nd, 2011, 04:08 PM   #5
ryanw's Avatar
thanks
255 fuel pump,
3:27 gears
Old December 5th, 2011, 11:53 AM   #6
95Pony is on a distinguished road
I too agree with ryanw, 42's are almost right in the middle for a lot of boost pressures. They are a lil big for 6lb's but once you hit 8-14 they're perfect. I would have to say even if you got a calibrated MAF, it's still in your best interest to get it tuned (at least i saw gains with a calibrated MAF and a tune, better idle as well).
Dart Iron Eagle block & Pro 1 heads
DSS 347
80lb injectors
D1-SC
blueovalindustries headers
BBK o/r X
Flowmaster cat-back
3.73 gears
Old December 13th, 2011, 09:48 AM   #7
99FiveOh's Avatar
1999 Mustang
99FiveOh is on a distinguished road
I wouldn't recommend using the stock MAF with any tune. That blower will move way too much air for the stock MAF. Not only is it too small(will be an airflow restriction which leads to less boost), but you'd peg it out every time you stomp on the gas pedal.
Other than that, I agree with Ryan as well.
1999 V6 Vert converted to 5.0 EFI with Vortech V2 SQ, Edelbrock Performer intake, BBK shorties, O/R H, Flowmasters, 42lb injectors, 75mm Pro-M with MAFia extender, 255lph fuel pump. SCT tuned 370 rwhp 400 rwtq.
Threads Similar to: Supercharging
supercharging help 79frankinstang 5.0 Mustangs 24 November 15th, 2010 12:46 AM
supercharging stangboy33 99-04 13 July 26th, 2010 11:59 AM
Supercharging? plove71387 V6 Mustangs 25 December 3rd, 2007 10:08 PM
Need Help With Supercharging 07 GT project07GT 2005 - 2010 31 November 16th, 2007 01:32 PM
most HP you can get without supercharging? rudedude101 Modular Mustangs 4 February 26th, 2007 03:40 AM
