Suspension Overlooked
Old December 15th, 2011, 04:50 AM   #1
Foxmoto28's Avatar
'94 GT Coupe
Foxmoto28 is on a distinguished road
I understand the fact that when you lower a vehicle you're changing the center of gravity.
I know you'll need the following:
Larger wheels and wider tires
Aftermarket springs, shocks and struts - leaf springs on some?
Thicker front and rear sway bar
Aftermarket caster chamber plates
Also, good time to replace ball joints, etc.
I currently have:
Eibach lowering springs (Getting the add on coil over kit for Christmas )
Aftermarket shocks and struts; I'll look at the brand, my brother did that one.
17" rims with wide tires, wider in the rear.
And I recently changed the ball joints.
What else am I missing?
and what are some good brands?
I'm thinking about getting the Eibach sway bar kit (front, rear, and bushings) whenever I get my coil over.
Old December 15th, 2011, 10:15 AM   #2
johnGT's Avatar
1995 Mustang GT vert
johnGT is an unknown quantity at this point
Our cars don't have leaf springs or a place to bolt them in for that matter I don't think.
Most people say you will need a bumpsteer kit when you lower your car. I personally don't like them, but it's all preference I guess.
Adjustable camber plates are good to have with a lowered car. Depending on the size tire, it will be bowed outward in front.
For the sway bars, I would just get new bushings for the front one and get a thicker one in the rear. Most of the body roll is in the rear. Generally, the thicker the one in the front, the more understeer you will get but the car will feel more stable. This is because the sway bar essentially doubles the spring rate of the shocks because it makes them work together. The thicker the one in the rear does the same but will cause a tad more oversteer because there is less flex. Once again, it all comes down to personal preference.
What size width are the tires going on there?
1995 Mustang GT vert: STOCK, AODE (B&M shift kit), 2.73 gears, red leather, 410,000~ miles.
2007 Mustang GT: 4.6, 5-speed, 3.55 gears, black on black. (dads car)
1975 Camaro LT: 305ci, TH-350, weiand intake, 600cfm carb, 3.42 gears.
Old December 15th, 2011, 10:48 AM   #3
MANZO MUSTANG's Avatar
1994 MUSTANG GT
15.15 @ 94.12
MANZO MUSTANG is on a distinguished road
Full length Subframe connectors.
1994 Ford Mustang GT, 306CHP(260rwhp)
Auto,MM Full Length SFC, otherwise stock suspension.
Old December 15th, 2011, 11:20 AM   #4
wiggety wiggety whack!
brokenweasel's Avatar
brokenweasel is a glorious beacon of lightbrokenweasel is a glorious beacon of lightbrokenweasel is a glorious beacon of lightbrokenweasel is a glorious beacon of lightbrokenweasel is a glorious beacon of lightbrokenweasel is a glorious beacon of light
where is jazzer?
I'll fill in for the kitty:
What are the ultimate goals for your ride?
One possibly overlooked thing to do when lowering: put those caster/camber plates to good use and get an alignment.
What coil-overs are you getting? Read everything on these two websites and then you'll get a better idea of what you need to do. The best thing you can do for yourself is learn what everything does and how it works together, that should help you decide what suspension upgrades need to be addressed first.
http://www.griggsracing.com/
http://www.maximummotorsports.com/
Originally Posted by dr.gonzo? View Post
Monkeys wear spandex with hotdog legs because race car.
Originally Posted by IndianaJoe View Post
yesterday was shorter because of the massive burnout i did, it spun the earth faster.
Old December 15th, 2011, 12:01 PM   #5
fogged306's Avatar
89 GT
Lol, got an explanation as to why you don't like bumpsteer kits? If you lower a car and change the angle of your tie rods enough, then your steering wheel will grab every little bump in the road. I lowered my car without a bumpsteer kit at first and you could see the tie rods were at huge up angle compared to the A-arms. The car was a nightmare to drive, grabbed every grove in the road and jerked the wheel when I hit a decent bump. I got a bumpsteer kit and got my tie-rods lined up with my A-arms and it was a night and day difference. The problem gets exponentially worse the lower you go, but once you lower a car, without a bump-steer kit on, your geometry will be off. A small amount you probably won't notice. I went probably 1.5" to 1.75" lower and you're not driving a car that much lower without a bumpsteer kit without fighting it all day long.
To answer the OP's question, You don't need larger wheels, or thicker sway bars. My sway bars are completely removed on my car. Caster camber kit, bumpsteer kit and lowering method of choice is all you need. New ball joints are a good idea as a preemptive replacement, but if they're not bad yet, it's not completely necessary. If you do lowering springs, make sure you do shocks and struts to match. I just cut a coil out of my rear springs and got a set of adjustable shocks for the rear and then went with coilovers for mine. My car is set-up for drag though. Guy at the suspension place I got all my stuff from said higher mileage V8 springs with a coil cut are actually great for launching if the rest of the suspension is up to par. He was right, car hooks hard.
Old December 15th, 2011, 12:36 PM   #6
johnGT's Avatar
Bumpsteer kits just make the car feel slower in the turns. Like there isn't enough power to move the wheels I guess. I like being able to turn quickly. Personal experience made me dislike them. Although the car I was driving was only lowered 1".
Old December 20th, 2011, 10:16 AM   #7
Daves94vert is on a distinguished road
Brakes! minimum i'd go with is some slotted/cross-drilled rotors and a 99 and up 2 piston caliper conversion with some hawk hps pads. Or cobra 13" brake setup.
Old January 4th, 2012, 01:16 AM   #8
1992 Mustang LX
13.0 @ 105
StangBanger302 will become famous soon enough
Wtf? Hes asking about suspension and you suggest brakes? I'm clueless...lol.
As I lay rubber down the street
I pray for traction I can keep
But if I spin, and begin to slide
Please dear God, protect my ride
Old January 7th, 2012, 09:55 PM   #9
Foxmoto28's Avatar
'94 GT Coupe
Old January 13th, 2012, 09:18 AM   #10
You need a good braking system to take full advantage of your suspension.
Old January 26th, 2012, 01:38 PM   #11
Macunicorn's Avatar
Macunicorn will become famous soon enough
You won't need sway bars until the end. They are used as a tuning aid.
You will need welded in subframe connector to eliminate chassis flex etc,
A good set of Lower Control Arms will control wheel hop etc,
And depending on ur goals you will need a pan hard bar to keep the axle
centered under the car by reducing lateral movement during cornering.
And you will need a good alignment and possibly bump steer kit depending
on how much is lowered.
Sig by Tricep
Old February 2nd, 2012, 06:48 PM   #12
95StangMX's Avatar
95 Mustang GT
What the heck does having those brakes have anything to do with "taking advantage" of the suspension, if the car doesn't have many engine mods, its not going to go fast enough that the brakes can't handle it, hell I am still running the stock brakes on my car or was until I took it apart, and will use them again with the 347 stroker thats going in, and our 1/4 mile is short as far as having room to slow down after the 1/4.... they work fine for me....
Old February 6th, 2012, 04:43 PM   #13
The suspension pieces he's looking at are more for autocrossing than drag racing. Our stock brakes aren't sufficient for our stock cars much less a modified car. Not all cars go straight only. Some turn too. Go hit a road course and reply back if your stock brakes are good enough. Didn't realise this was a drag race only forum.
Old February 7th, 2012, 12:06 PM   #14
Bullitt95's Avatar
1995 Mustang GT auto
13.546 @ 105.32
Bullitt95 will become famous soon enough
You'll soon change your mind about the stock brakes if you swap in the 13" fronts from a '94-'98 Cobra. I've done that swap and the improvement in stopping power was very noticeable. The Cobra front brakes are also less prone to fade.
Old February 7th, 2012, 05:37 PM   #15
johnGT's Avatar
+1.^
I have the stock brakes (yes, they are horrible) but I noticed a HUGE difference when I had my front struts replaced. Less nose dive = better stopping power = better handling.
Old February 9th, 2012, 01:52 AM   #16
1995 Mustang GT
GreenCobraClone is on a distinguished road
Thank you. You just explained why my car tracks with the ruts in the road. Bump steer kit is next on the list.
95 Dark Green Cobra Clone...BBK Longtube Headers, Stainless Flowmaster Exhaust, Underdrive Pulleys, BBK CAI, MSD distributor cab, MSD Blaster Coil, Smog delete, Steeda short throw shifter, 4:10 rearend gears, lowered 2" via eibach lowering springs
Old February 9th, 2012, 02:07 AM   #17
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
You dont need cobra brakes or 13" brakes to stop good. All you need a set of OEM GT rotors, new new edge calipers, a good set of brake pads, stainless brake lines and DOT 5.1 or better fluid.
And with this set up you will have brakes that will out perform factory cobra brakes
Threads Similar to: Suspension Overlooked
The Most Overlooked Accessory carid CARiD.com 1 August 31st, 2011 10:05 AM
Overlooked Modifications to a Classic Stang? Fishrmn703 Classic Mustangs 3 December 8th, 2010 12:57 AM
10 overlooked muscle cars (with pics) Enzo_Guy All Other Vehicles 17 June 14th, 2010 02:38 PM
Steeda Suspension- Suspension Questions MustangJon255 2005 - 2010 22 June 2nd, 2010 05:43 PM
Suspension for 99 ArmyChargedGT 99-04 18 March 20th, 2008 11:14 PM
