Discussing problem in the 94-95 Forum. i have a bit of problem with my mustang, i have a 94 mustang GT ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
1994 Mustang GT
problem |
never heard of egr doing that but i guess anything is possible
1966 LUBR Bronco 1979 2.3t Cobra 1994 V6 Vert & a 351 ON A STAND 1997 Black Cobra 1994 Jeep XJ 4.5" lift 33"MTR http://www.cardomain.com/ride/680999 http://www.myspace.com/beheivjer |
sounds like detonation. My 95 has been doing it, and i think i got it stoped. ANd it was the EGR. SO, you can either unhook the EGR vacuum line, and plug both sides, or buy a new one and swap it out.
Fast, Cheap or Reliable. You get to pick TWO! |
1995 Mustang GT AODE
13.87@101.3
Yes, it does sound like detonation and one common cause is the EGR valve getting stuck open causing the engine to run too lean. You can either take it out, clean it, and reinstall it, or just delete it altogether and plug an EGR eliminator simulator into the wiring harness to prevent the "check engine" light from coming on.
Another possibility is clogged injectors causing a lean condition though with just 66k miles, this seems pretty unlikely. You can try a fuel system treatment with a bottle of injector cleaner and see if that helps. |
Threads Similar to: problem
| umm have a weird problem? idle problem? | blue03mach1 | 99-04 | 16 | March 4th, 2008 12:03 PM |
| Has your car ever had a problem? | JASonic | The Clubhouse | 17 | September 19th, 2007 05:19 PM |
| big problem need help | 96gtponyred | 96-98 | 12 | August 22nd, 2007 01:36 AM |
| RIM Problem and Help | trueballerisme | 2005+ | 70 | August 21st, 2007 08:55 PM |
| TPS Problem? | 88Horseman | 5.0 Mustangs | 11 | November 13th, 2006 11:46 PM |
