1995 Mustang GT
Question About Thermostat Housing Gasket
I have a bit of a leak coming from the thermostat housing so I decided to change the gasket, the first one I bought was really thin and still leaked after the install, got a new one today made of cork and hoping it will do the trick, the question is, should I apply RTV silicone as well or will that damage the gasket? Also I plan on lightly sanding the mating surfaces to ensure they're both clean and flat.
Hurst Billet/Plus SST Short Throw Shifter, 1999 SVT Cobra Wheels, BBK O/R H-Pipe, Flowmaster American Thunder Catback Exhaust System, 5% Window Tint On Back 3 Windows, Eibach Pro-Kit Lowering Springs, Eibach 1" Wheel Spacers, BBK Cold Air Intake. |
1995 Mustang GT
ttt
SG
2005 Mustang GT
2001 Mustang V6
Yes, make sure you get all dirt/debris off of the surface. Applying RTV around the gasket will not hurt anything at all. In fact, I did that the last time I changed my thermostat on my 01' and I haven't had any problems at all.
01' V6: SCT tuned, Dual Flowmasters & H-pipe, 8000k 35w HID's, Steeda Short Shifter, BBK CAI, Eibach pro-kit, 3.73's and t-lok. 05' GT: SCT tuned, C&L Racer, FRPP cams, Pypes Pype Bomb's, Shorty Antenna, Painted Mirror covers, Decklid Panel |
1995 Mustang GT
Also one side of the gasket is a stick on type so like a sticker, should I apply RTV on that side or no?
SG
2005 Mustang GT
2001 Mustang V6
No need to, what I did was put the gasket on the thermostat like normal and tightened the bolts, then I went around they faying edge with the RTV.
94 GT
13.95@100
![]() iTrader: 2 reviews
I usually apply a thin layer, it helps keep the gasket in place while installing. If both surfaces are clean it will seal fine without.
94 Opal Frost GT ~230k T5 swap, other mods
1995 Mustang GT
Use brake clean on mating surfaces to remove oil coolant residue. Sanding housing on flat surface to remove imperfection and sanding with block on intake will help to seal. I use Fel Pro gasket. If using rtv, do so sparingly. No need for restriction from excess.
#8 | |
94 GT
13.95@100
Good point. I've seen many jobs done with excess silicone squished out the sides of the surface. My own Mustang had a leaky differential because someone used RTV like it was glue. When I do a gasketed surface, I spread it thin like mayo.
Threads Similar to: Question About Thermostat Housing Gasket
| Crack going down thermostat housing | TheOdessa | 99-04 | 27 | July 9th, 2011 08:58 PM |
| Thermostat housing question '99 GT | sillyrabbit0420 | 99-04 | 12 | April 28th, 2011 04:00 AM |
| stripped thermostat housing bolt :/ | jonnydankness | 5.0 Mustangs | 6 | February 20th, 2010 08:57 PM |
| HELP with thermostat housing | 01 blue bullitt | 99-04 | 9 | December 13th, 2008 12:52 PM |
| Chrome Thermostat housing. | jrfan4life | 99-04 | 9 | April 17th, 2007 05:37 AM |
