1994 Cobra Dying
Old January 3rd, 2012, 05:47 PM   #1
Tyler Mac's Avatar
1994 Mustang Cobra
Tyler Mac is on a distinguished road
1994 Cobra Dying
I just installed a cold air intake system from Summit Racing and I cranked it up and it ran fine. I ran down the road a ways and stopped and made sure the filter hadnt fallen off and everything was still tight. I stop at another stop sign and the car idles fine. Then at the next stop sign, it went into its low idle and abruptly dies. I refire it and it instantly comes back. It dies again when I pull into the yard. I crank it back up and it sits and idles perfect. I back up and then pull forward to see if I can replicate the problem. It idled back down, came close to dying, and then surged back and idled fine once again. Any thoughts and ideas would be appreciated! Thanks! And a list of upgrades: Summit cold air intake, under drive pulleys, off road x pipe and flowmaster pipes and mufflers.
Oh the joys of an F-body, but this Mustang isn't so bad.
http://www.facebook.com/home.php#!/tyler.mac70
Old January 3rd, 2012, 05:56 PM   #2
1995 Mustang GT
Bubba95SN is on a distinguished road
If you notice the MAF are sold in a different part number for cold air....I did not have a issue. Just saying. Check for unmetered air.
Old January 8th, 2012, 11:51 AM   #3
1995 SVT Cobra
Cobraman1024 is on a distinguished road
Some things to consider looking at:
1. did you remove the small screen at the input of the MAF when you installed the cold air kit? Try reinstalling it or removing it to see if it makes a difference.
2. "clocking" the meter properly. Try loosening the clamp holding the section of the kit that the meter is held to and rotate it slightly while the car is running. See if it makes a difference.
3. Is your intake air temp sensor still firmly in place to the cold air kit tubing? What about the vacuum hose that goes to the passenger valve cover at the oil filler spout?
4. Lastly, try disconnecting your car battery, wait a few minutes and reconnect it. Start the car up and let it idle for a few minutes. Take it around for a drive. The idea here is that some computers seem to be more sensitive to change than others; if you give the computer a clean slate to adjust its settings from, it might respond quicker and won't give you as much crap after installing a new part.
1995 SVT Cobra #182/4005, 275/305, 217k miles
1996 SVT Mystic Cobra #1666/2000, 267/263, 178k miles
1995 Mustang, 3.8L, 233k miles
1993 Mustang LX, 2.3L, T5 convert, 95 GT suspension swap, 03 Cobra steering rack, 250k miles
sold: 1987 GT
MM Military Crew Member
MM+Cleavage member #21
Old March 16th, 2012, 11:34 PM   #4
Look Ma! My First Post!
scottieb's Avatar
1995 cobra
scottieb is on a distinguished road
ive got a 95 and put a BBK cai and now same problem
Old March 17th, 2012, 12:45 AM   #5
NeverEnuff's Avatar
1989 LX Coupe
7.1@99mph
NeverEnuff has a spectacular aura aboutNeverEnuff has a spectacular aura aboutNeverEnuff has a spectacular aura about
Prob air flow disturbance across the MAF. Clocking the MAF housing (if you can) in different positions might help keep the air flowing across the meter consistanly.
89 LX Coupe-Carb'd 32v-437rwhp NA, 592rwhp N20
01 Bullitt-32v swapped
96 GT-Cammed E85
www.KPERacing.com
Old March 17th, 2012, 07:26 AM   #6
Bullitt95's Avatar
1995 Mustang GT auto
13.546 @ 105.32
Bullitt95 will become famous soon enough
Good call but another thing to consider is that some oil from your new filter might have contaminated the MAF sensor. If clocking the MAF housing doesn't solve the problem, you could try cleaning the sensor.
243.5rwhp/284.2rwtq
Mod list in My Garage
Old March 17th, 2012, 08:00 PM   #7
NeverEnuff's Avatar
1989 LX Coupe
7.1@99mph
True dat.
96 GT-Cammed E85
www.KPERacing.com
Old March 18th, 2012, 02:18 PM   #8
hotmustang95's Avatar
Last of the 302's
Road Racing Rookie
hotmustang95 is on a distinguished road
ALL OF THE ABOVE. Keeping that sensor clean is vital to how it works. New filters sometimes have way to much oil on them and that crap gets all over your sensor. Also like mentioned above, disconnecting the battery for a few minutes and reconnecting it and letting the car idle for a while will allow the computer to learn the new setup. As far as clocking your housing I've never tried it but I've heard about it quite often.
Victor ( goofyfeet) Oliver
P.B.M.C. Member
Track Addict
Threads Similar to: 1994 Cobra Dying
Wow my friend is dying ... no literally , hes dying Youngin The Clubhouse 54 July 21st, 2010 06:53 PM
1994 Cobra, What should it run? stangballer 5.0 Mustangs 19 December 16th, 2009 10:26 AM
1994 GT or Cobra powersrj 5.0 Mustangs 7 April 1st, 2008 10:40 AM
1994 Cobra EricACCfan 5.0 Mustangs 4 January 3rd, 2007 08:48 PM
1994 cobra troy1000rr General Tech 0 December 20th, 2006 01:41 PM
