twinturbo 95 with pms...what wideband???
Old January 8th, 2012, 07:37 PM   #1
bretts95gt's Avatar
95 mustang gt
bretts95gt will become famous soon enough
Ok im building a 306 with twin garrets 63mms, trackheat ported heads, efi spyder intake trickflow stage 2 cam, im running 48lbs trickflow injectors and a 90mm sct big air mass air meter (setup for 42lbs injectors) but I have a anderson pms that im going to use to get the air fuel right..... Heres my question for you guys what wideband is the best out there that youve found??? Inovative? Autometer? I want to be able to see both banks a/f
95 gt vert-custom fenders 03 cobra front end,twin garret turbos,ported trickflow trackheat heads, hks blowoff valve,spyder efi intake, underdrives,built c4, 4000 stall converter,reverse manual valvebody,4.10 gears
Old January 8th, 2012, 10:29 PM   #2
98SnakeHorse's Avatar
1995 Mustang Gt
98SnakeHorse is on a distinguished road
I've had really good luck with the inovatives lm1 and 2's
98 Cobra_stock bs/exhaust [SOLD]
2000 s/c gt, 511rwh 450rwtq [SOLD]
1995 331 Stroker Gt, (Turbo build in progress) - http://www.moddedmustangs.com/forums...-95-5-0-a.html
Old January 9th, 2012, 07:55 PM   #3
1995 Mustang GT
Bubba95SN is on a distinguished road
I have no problems with my innovative. Heads up, if you do buy their kit don't test the small red led on the 12v battery. It is like a 5v bulb. Will work very well briefly at 12v....New bulb wire socket s/h is like $22. Bubba
Old January 9th, 2012, 10:09 PM   #4
fogged306's Avatar
89 GT
Most LED's you find used in automotive applications are 3v. You can get those for pennies, literally. I have hundreds of them laying around my shop, lol.... Did you actually pay $22 for one?
Old January 10th, 2012, 03:45 PM   #5
BWAL Is My Hero
JakeM's Avatar
2003 F150 S-Crew 5.4 FX4
JakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant future
Doesn't the PMS log Wideband? If not, I'd go with a NGK AFX Wideband. Best wideband for under $1500. Use the NTK sensors, the same sensors most Lab Grade WBO2's use.
Home » Shop » Wideband O2 » O2 Controller » NGK Powerdex AFX - Air Fuel Ratio Monitor Kit - Wideband O2 - PN 91101 - w/ NTK Sensor
*My YouTube channel*
Member# 1 of the Zip Nutswinger Bandwagon of Love.
Originally Posted by dr.gonzo? View Post
That drunk guy ran like I do after I fart in the store
Old January 10th, 2012, 09:25 PM   #6
1995 Mustang GT
Yup, went to led are us .net Something like that, could not find the exact same bulb in deminsion for insert. I was really disappointed cause the things are like a dime. Bit the bullet. Seems they would put a warning that led is only 5v. Tested new one with 3 AA batteries. Drilled hole in clock delete for light. Had a blue or white 5v led but center top of dash, those choices are not good. Not one of my favorite moments to remember, oh...no,damn.
Old January 10th, 2012, 10:18 PM   #7
fogged306's Avatar
89 GT
Damn.. I think I might have to re-write the business plan, lol.
Old January 11th, 2012, 04:02 PM   #8
1995 Mustang GT
There is a medical term for what happened....brain fart.
Old January 12th, 2012, 08:19 AM   #9
bretts95gt's Avatar
95 mustang gt
I think the pms can log air fuel but you have to buy add ons I think (not positive someone correct me cause that would be perfect) Im just needing something to get the job done we dont have many street racers here anymore and alot of people got out the car scene so im basiicaly the one left so Im just wanting to putt around for now
Threads Similar to: twinturbo 95 with pms...what wideband???
Please Help Need To Know What Stall Converter To Get For The Twinturbo?!?!?!?!?!?! turbofox1 General Tech 1 August 9th, 2010 12:13 AM
Ran The Twinturbo For The First Time turbofox1 Drag 7 July 14th, 2010 07:37 PM
TwinTurbo/Procharger/Supercharger serbiandude 2005 - 2010 V6 10 April 1st, 2010 12:59 PM
need help with wideband..... 88stangGT 5.0 Mustangs 10 October 30th, 2008 06:41 PM
