428 cobra jet engine
Old January 9th, 2012, 11:27 AM   #1
tw807b is on a distinguished road
i have a 1995 Mustang gt bone stock i'm looking to replace the engine with a 428 cobra jet engine that has been given to me i want to know is this possiable and what do i have to do to make this possialbe and what has to change the friend that is giving me the engine has been takin out of a 1970 mach one he used to race and it pushes around 1200 hp so what all has to change for this to go into my car if it can at all
Old January 9th, 2012, 07:49 PM   #2
1995 Mustang GT
Bubba95SN is on a distinguished road
AHH.. damn, that there engine will twist your car into a pretzel! Roll cage, full frame front to rear, different differential. That would be a start.
Old January 9th, 2012, 07:55 PM   #3
price wise what am i looking at ?? and i kinda need detailed explanation as i'm not realy savvy when it comes to mechanics i'm gonig to have mechinc put it in
Old January 10th, 2012, 09:25 PM   #4
1995 GT
h949h is on a distinguished road
probably quite a bit, the most expensive part is going to be the mechanic if you go that route, labor is pretty pricey ATM.
Old January 11th, 2012, 02:15 AM   #5
Mustang Boy's Avatar
1994 Mustang GT
14.582@92.58MPH
Mustang Boy will become famous soon enough
Send a message via AIM to Mustang Boy Send a message via MSN to Mustang Boy Send a message via Yahoo to Mustang Boy
Cool
For everything to support that power you are probably looking at the $10k+ range with labor.
315's Crew
Black and White Crew
Crew Member #2
Old January 16th, 2012, 03:45 PM   #6
94bossgt's Avatar
94 mustang gt
too slow to tell
94bossgt is on a distinguished road
trans rear exhaust cage sfc battle boxes suspension fuel system basically your turning your car into a full on race car will cost alot of cash and idk about your driving abilities but if its pushing that kinda power it might be a recipe for disaster
Old January 16th, 2012, 04:02 PM   #7
Priest of the Car Gods
ReverendDexter's Avatar
Clapped-out '90 GT 'vert
~5.5 seconds off TTOD :(
You're basically looking at doing all the same things you would for a 460-swap (which is well documented), plus probably custom motor mounts, and a whole gob of chassis reinforcement. I'd be looking at something like Griggs' over-and-under subframe connectors PLUS at the very least a 6-point rollbar that ties the front and rear of the car together.
Then of course, the suspension and tire to get that power to the ground.
O o
/¯/______________________
\_\
Old January 18th, 2012, 05:25 PM   #8
95project is on a distinguished road
Dude, it must be an extremely good friend to give a cobra jet...i hope you drive better than you punctuate
My guess would be absolute lowest 10K if you are not doing the work...i imagine suspension and all the fab work needed to make that beast fit would be 10k or more...
Good luck bro!
95 GT- AFR 185's, Comp CAM, Trick FLow TH upper and lower, 30lb injec, 76MM C&L kit, Full MSD, BBK Pulleys, 3:73, BBK Long Tubes, X Pipe, Magnaflow Cat back, Cobra front control arms, MM CC plates LCA's and Panhard bar, tuned by Adam @ Pops Racing.
Old January 21st, 2012, 10:41 PM   #9
1995 SVT Cobra
Cobraman1024 is on a distinguished road
If you're trusting a mechanic to install this engine for you, I'd learn how to do this myself if I were you. That or make sure you can identify that engine after it's been installed as the one you gave him to install lol
1995 SVT Cobra #182/4005, 275/305, 217k miles
1996 SVT Mystic Cobra #1666/2000, 267/263, 178k miles
1995 Mustang, 3.8L, 233k miles
1993 Mustang LX, 2.3L, T5 convert, 95 GT suspension swap, 03 Cobra steering rack, 250k miles
sold: 1987 GT
MM Military Crew Member
MM+Cleavage member #21
Threads Similar to: 428 cobra jet engine
which engine for 1500 rwhp 2003 cobra 1999 cobra or 2000 gt gtjason New Members Introductions 14 February 19th, 2012 09:19 PM
Cobra SVT engine vs Tuned SOHC engine War 99-04 16 November 10th, 2010 12:45 PM
98 V6 engine to 98 Cobra engine swap 98SN-95 V6 Mustangs 0 August 3rd, 2010 03:12 AM
So what is better a crown vic engine or cobra engine? chocolate The Clubhouse 16 May 6th, 2010 12:39 PM
2003-04 cobra engine in 1996 cobra hedgehog 4V / SVT 6 December 9th, 2009 10:05 AM
