95 brake light fuse
Old January 27th, 2012, 01:00 AM   #1
PerfectlyInsane is on a distinguished road
95 brake light fuse
I just bought a 95 gts and the only propblem im having with it is that my #9 fuse keeps blowing. I have already replace the flasher, brake switch, and checked all the visible wiring from front to back. I had also noticed that my clutch posion switch is no good because i can start the car without the clutch. I just wanted to know if it could be the clutch posion switch that is blowing the fuse or do i have to start going through every inch of the wiring to find it.
Old January 30th, 2012, 01:32 AM   #2
ok i figured out the acton that was causing the fuse to blow. everytime i down shift and i let the clutch out before the brake is when it blow. i haven't done that in 3 days now and the fuse is fine.
Old January 30th, 2012, 09:31 PM   #3
1995 Mustang GT
Bubba95SN is on a distinguished road
Clutch switch area needs more investigating.
Old January 31st, 2012, 12:45 AM   #4
bought the cluch position switch, having trouble tring to pull the pin that holds it to the pedel. very tight space for both hands and a head.
Old January 31st, 2012, 10:52 AM   #5
99FiveOh's Avatar
1999 Mustang
99FiveOh is on a distinguished road
Yup, really tight under there. Helps to pull the seat out and lay under the dash comfortably. Trust me, it'll take way less time to pull that seat out than trying to do it with the seat in.
1999 V6 Vert converted to 5.0 EFI with Vortech V2 SQ, Edelbrock Performer intake, BBK shorties, O/R H, Flowmasters, 42lb injectors, 75mm Pro-M with MAFia extender, 255lph fuel pump. SCT tuned 370 rwhp 400 rwtq.
Old January 31st, 2012, 09:38 PM   #6
1995 Mustang GT
Remove the seat, you'll be glad you did.
Old January 31st, 2012, 10:48 PM   #7
99FiveOh's Avatar
1999 Mustang
Off topic but please OP shrink your sig pic a little, it'll make us and the Admins much happier!
Old February 1st, 2012, 12:47 AM   #8
how is this
Old February 1st, 2012, 12:49 AM   #9
99FiveOh's Avatar
1999 Mustang
looks like the same size. It helps to get a shot of your car that you can narrow down to a banner sized pic.
Old February 1st, 2012, 12:06 PM   #10
94 GT
13.95@100
furreal302 is on a distinguished road
sounds like it *might* have something to do with the cruise control system?
94 Opal Frost GT ~230k
T5 swap, other mods
Old February 8th, 2012, 11:07 PM   #11
BlownSnake95 is on a distinguished road
found your fix (maybe)
hello i was searching for a fix to the same problem. i ran across this thread and went down with car off started pushing the clutch pedal, and heard the fuse blow. i did some more research and found the wiring runs across the very top of the clutch pedal and is a pain in the ass to get to. i pulled them down far enough to see them and sure enough bare wire. taped and moved to keep away from clutch pedal and it fixed it will post link to thread that helped me on next post
Old February 8th, 2012, 11:08 PM   #12
#9 fuse keeps blowing Help!
here is hte thread that helped me (look for post that has pics of solution)
Threads Similar to: 95 brake light fuse
HELP - blew fog light fuse/relay??? austin101385 General Tech 19 February 27th, 2012 10:23 AM
2001 Cobra blowing brake fuse 2001cobra_conv Electrical & Wiring 1 March 7th, 2011 02:48 PM
Airbag Light, Brake Light, and Random (Pulley?) Whine CarmenVI V6 Mustangs 11 March 5th, 2011 03:15 AM
location of brake light fuse 2006 gt xxxscimitarxxx 2005 - 2010 4 March 9th, 2008 07:35 PM
Brake light switch problem after upgrading brake booster black88 5.0 Mustangs 2 January 20th, 2008 11:41 PM
