Bbk pressure reg
I just got my regulator in today and its for a 87 _ 93 I dnt wwant to send it back for right one and wait 2 more weeks I was told it wiill fit on my 95 5.0 is this true?? Please verifythis an whaats the diference
No it won't work on a '95.
![]() 243.5rwhp/284.2rwtq Mod list in My Garage |
![]() iTrader: 1 reviews
Wil not fit went through the same thing send it back
95ish5.0
here's a question: are the adjustable regulators worth it? I debated on whether or not I wanted to buy one when I replaced the Fuel pump.
It depends on what mods you have. If you're in the same in-between situation as I am where your mods will near max out stock 19lb/hr injectors at WOT but you don't have enough mods to warrant 24lb/hr injectors, an AFPR will allow you to raise the fuel pressure to get more fuel flow out of your existing injectors.
The stock injector flow is rated at 39psi. If you raise the fuel pressure to 45psi, injector flow increases to 20.4lb/hr.
#6 | |
95ish5.0
1995 Mustang GT
Hook up a fuel pressure gauge. Watch the pressure as you drive down the road.
Threads Similar to: Bbk pressure reg
| No oil pressure at all | Mr Switchez | 99-04 | 27 | April 15th, 2011 08:16 PM |
| What should oil pressure and fuel pressure be | stevo306stang | 99-04 | 2 | March 28th, 2011 09:15 PM |
| New Oil Pressure Gae, New Pressure Readings | 99GT35thLE | 99-04 | 2 | March 18th, 2011 09:13 PM |
