Mach 460 question (line converter wiring)
Old February 2nd, 2012, 05:55 PM   #1
1995 GT
4Ever
Red95_5Oh is on a distinguished road
Send a message via AIM to Red95_5Oh
Hey everyone,
I ran RCA's to the trunk, used a line converter to wire them into the harness at the black plugs on the amp. The amps turn on, the subs work, but do not hit. They hit once real well then nothing.
My question on the wiring of the line converter, do I have to bridge them (L+, R-, L-,R+) or Straight (L+,L-,R+,R-).
Old February 2nd, 2012, 07:06 PM   #2
nkausch's Avatar
94 Mustang Gt
nkausch will become famous soon enough
I thought it was straight but I could be wrong. It sounds like there is something wrong with the ground which is why it would hit once and then stop
94 Mustang Gt Vert-Mods: Tubular Headers, BBK Catted X, SLP Loudmouth 2's, EGR Delete
Old February 2nd, 2012, 09:16 PM   #3
94 GT
13.95@100
furreal302 is on a distinguished road
I did the same thing as you with a high/low level converter. I tapped into the signal at the rear speakers, so all I had to run was the power wire from the battery. I just wired it in straight left to left and right to right. It works great and I enjoy the clean look of the factory cd player.
94 Opal Frost GT ~230k
T5 swap, other mods
Old February 2nd, 2012, 09:26 PM   #4
1995 GT
4Ever
i bet its my door speaker loose ground...
Old February 9th, 2012, 06:06 PM   #5
1995 GT
4Ever
Update:
I figured it out.
1) Door speaker leads where backwards. I figured since the blk/lg wire coming off the amp was negative, that the lead to the speaker would be negative. No, no it is not.
2) RCA's to rear amps. Ok so took me forever to find this, asked my cousin who has alldata to look it up. So I am pretty sure, if I remember correctly, you wire the RCA's into the black plug. So if the plug is plugged into the amp and your looking at it, the three wires are on the right side, two on top, one on bottom. Left top is +, Right Top is -, The bottom wire is +5V turn on. Just remember whatever side that the BLK/LG wire is, is the + side for both plugs.
3) Used cheap RCA cables the first time. When I bought the hi-low converter, i used cheap RCA cables with very thin wires when I cut the tips off. Replaced those with a nice set of wires ( =( ) and worked great with out line converter.
Not bad at all now. Its super simple to wire in the harness too. You do not need one of those wiring harness if you want to just cut the connectors off from the car side harness. You dont even need a line converter if you run RCA's to the trunk then cut and wire them into the amps. Sounds 1000% better.
Threads Similar to: Mach 460 question (line converter wiring)
Mach 460 wiring questions V8ornothing Audio/Video 12 July 15th, 2011 12:14 AM
Line out converter? JerseyTrueBlue Audio/Video 2 August 1st, 2009 09:36 PM
72 mach wiring question Mach1460 Classic Mustangs 1 September 20th, 2008 10:31 PM
mach wiring harness ROUSHME661 Audio/Video 4 August 5th, 2007 10:41 AM
