94 EFI problems
my 94 gt is running really weird
the car runs fine......until it warms up then it will idle really low and the trans drops into 2nd gear it will only do this when it runs bad other then that it shifts fine and doesnt slip at all you have to give it gas to keep it alive does anyone have any idea what the problem could be?
![]() TEAL1994GT(: |
1995 Mustang GT vert
Get hold of an OBD-I code reader and write down any codes you have (most auto zones/advanced auto stores have them to use if you can't buy one). The plug-in is on the driver side strut tower under the hood. If they try to plug it into the one under the passenger dash, call him an idiot and point him in the right direction. (unless your car is a v6)
Bring us back some codes if you have any and we will go from there. 9 times out of 10 problems can be traced back to the code. You may also want to try cleaning your MAF sensor and check for any vacuum leaks. (any lose/broken rubber hoses under the hood)
1995 Mustang GT vert: STOCK, AODE (B&M shift kit), 2.73 gears, red leather, 410,000~ miles. 2007 Mustang GT: 4.6, 5-speed, 3.55 gears, black on black. (dads car) 1975 Camaro LT: 305ci, TH-350, weiand intake, 600cfm carb, 3.42 gears. |
#3 | |
1994 MUSTANG GT
15.15 @ 94.12
![]() iTrader: 1 reviews
1994 Ford Mustang GT, 306CHP(260rwhp) Auto,MM Full Length SFC, otherwise stock suspension. |
Threads Similar to: 94 EFI problems
| new with temp problems and trans problems | 89Bullitt | 2.3 Mustangs | 4 | September 18th, 2010 03:14 PM |
| Ugh more problems! | KV007 | 96-98 | 12 | September 3rd, 2010 02:47 AM |
| help ac problems | reeds98gt | Modular Mustangs | 0 | August 27th, 2010 11:47 AM |
| Problems | WAR-PARTY | 99-04 | 0 | January 14th, 2008 07:26 PM |
| A/C problems | throwedoff | 99-04 | 3 | September 25th, 2007 07:42 PM |
