Under Drive Pully will help???
Old June 16th, 2007, 06:45 AM   #1
stang94 is on a distinguished road
I just need a guess here guys, I know dyno will be the best. But I will be doing heads and cam next year maybe switch to 351. But for now I just need a guess.
94 5.0 Vert
Trick Flow Upper and Lower
75MM TB
BBK CAI.
BBK Shorty
BBK o/r x-pipe
Flowmaster 40's
Hurst Short Shifter
Front 245/45/17
Rear 275/40/17
I already got a set of alum. BBK Underdrive Pully to be install.
Gripp SubFrame Connector
Gripp Upper and Lower Control Arm.
I am getting Ford Racing 3.73 Gears in about 3 weeks.
and its 5 speed.
Any guess how much power will I be putting down?
And is there any small minor stuff should I looked at to get?
Giving Away For FREE PM ME.
FREE 351 Block, 90,xxx miles (Non roller block)
FREE 94-98 GT Hood (red)
Old June 18th, 2007, 12:33 PM   #2
Racinjason81 is on a distinguished road
my guess would be around 220-230 rwhp but thats just a guess.you should soon get a larger MAF meter and get 24lb injectors so you dont have to worry about running lean when HP level gets to the 19lb injectors
limit
Heres a real funny video
youtube.com/watch?v=ojB7KkaR03I
VTEC stands for Very Torqueless Economy Car
Honda stands for Hold On Not Done Accelerating
1991 LX 5.0 H/B(T-70 turbo coming soon)
Old June 18th, 2007, 05:36 PM   #3
Bullitt95's Avatar
1995 Mustang GT auto
13.546 @ 105.32
Bullitt95 will become famous soon enough
I'd say a little higher; 230-240rwhp. You'll definitely need a higher-flowing fuel pump, injectors, and a MAF calibrated to those injectors when you decide to do the heads/cam. Your existing 19lb injectors and 88lph fuel pump are pretty close to the limit.
243.5rwhp/284.2rwtq
Mod list in My Garage
Old June 18th, 2007, 07:22 PM   #4
thanks guys, I was hoping for about 230rwhp. and I just manage to pick up a set of holley 24lbs injector for $50, I guess the dude does not know what he have. It's seal in the plastic case, never open. I am planning on getting 225lph, thats not over kill is it? cuz I am planning on a turbo down the line, not right now though.. way down the line. ad for MAF what should I get?
Old June 18th, 2007, 07:23 PM   #5
Old June 18th, 2007, 11:47 PM   #6
to set up your fuel system for turbo this is what your gonna need,42lbinj,
a 255lph forced induction fuel pump, AFPR,and a C&L 76mm MAF sensor.
the stock cam works well with turbo for more power with a good idle use an FMS E cam and if you want a little more power with a rougher idle use a FMS F cam.the C&L 76mm MAF is great since you dont need to send it out to get recalibrated when you change injectors,you just buy calibration tubes $25.00each for different injector sizes.the C&L also works good with turbo on draw thru applications. the 42lbers and 255FI fuel pump probably would be overkill until you do your turbo kit.Im installing a Turbo on my LX soon so ive done my research.For more info on turbos checkout Turbomustangs.com
Old August 2nd, 2007, 07:57 PM   #7
nikbait's Avatar
nikbait is on a distinguished road
Send a message via AIM to nikbait Send a message via Yahoo to nikbait
Would ud pulleys make the car run hotter? I've heard that they can. If you mod a 5.0 and put in an ud pulley, do you have to upgrade your cooling system?
Because I'm the best there is at what I do, and what I do best isn't very nice.
Old August 3rd, 2007, 04:54 PM   #8
Bullitt95's Avatar
13.546 @ 105.32
I installed an ASP underdrive crank pulley on my 5.0. It was running slightly hot anyway but the pulley didn't make it any worse.
As far as upgrading the cooling system goes, I'd recommend swapping in a Mishimoto aluminium radiator. The stocker is marginal at best and in hot weather it just doesn't cut the mustard. I'm going to say bye bye to my stock radiator as soon as my wallet recovers from my latest parts buying spree.
243.5rwhp/284.2rwtq
Old August 3rd, 2007, 05:39 PM   #9
nikbait's Avatar
That's what I figured. A new radiator and probably new thermostat and water pump?
Old August 4th, 2007, 04:37 PM   #10
Bullitt95's Avatar
13.546 @ 105.32
The stock water pump is OK but when the time comes to replace it, the Stewart water pump sold by Summit Racing would be a good replacement.
If you live in a cool temperate climate, stick with the OEM 192* t'stat. If you live in a state that's warm pretty much year round, a 180* t'stat would do nicely.
243.5rwhp/284.2rwtq
Old August 5th, 2007, 01:13 AM   #11
nikbait's Avatar
Cool thanks for the info.
Old August 5th, 2007, 04:02 AM   #12
¡ʇsnq ɹo uʍop ǝpısdn
Onemanzu's Avatar
more then me
Old August 13th, 2007, 01:30 PM   #13
just_a_Gt's Avatar
just_a_Gt is on a distinguished road
220 hp
Threads Similar to: Under Drive Pully will help???
rpm outlet u/d pully blazor V6 Mustangs 13 August 27th, 2007 02:08 AM
Power Steering Pully woodallap V6 Mustangs 1 June 24th, 2007 11:07 AM
Pully Kit wonders_of_a_V8 Classic Mustangs 1 March 27th, 2007 05:52 AM
Underdrive Pully Question 2much4u 99-04 11 November 12th, 2006 06:26 PM
alternator pully notsoslo5.0 5.0 Mustangs 5 July 31st, 2006 05:34 PM
