Fuel Injectors
Did anyone have any problems with changing to higher flow injectors. With 24lbs. my car doesnt want to run at all and I have a 24lb maf. I am running the stock pump, is it possible that the stock pump just doesnt flow enough? Also do you have to recal the computer? Any help will be greatly appreciated.
2002 Roush 360R
![]() iTrader: 4 reviews
hey no the problem with 94 95 mustang with the 5.0 is the computer. You can go get a dyno tune and chip put in to correct it or find your self a cobra ecu and put in. The cobra ecu works on 24 lb. injectors and 24 lb maf. but a GT only works with 19lb
So I can go to Napa and get a cobra computer and a maf and everything will work fine with my injectors? I wont have to switch any of the pins?
2002 Roush 360R
you should be able to buy one Ive never done it but Ive thougth about it and did the research about it. Try ebay for the cobra ecu. And last resort FORD. the maf and injectors you got should work then with the cobra ecu and I dont think you have to switch any pins or wires
So do you think that I will need to change the pump? If I need to what flow rate should I go with? Thanks for all of the help.
Also when i get the Cobra Computer, is there a certain ID# that I should get or does it really not matter?
Threads Similar to: Fuel Injectors
| Fuel Injectors | Mach Boy | 99-04 | 3 | November 7th, 2007 08:32 AM |
| Fuel Injectors/fuel pressure | 00silvergt | 99-04 | 4 | August 2nd, 2007 09:54 AM |
| Fuel injectors | ByPopularDemand | V6 Mustangs | 10 | June 23rd, 2007 10:09 PM |
| Fuel injectors | ssdell3 | 99-04 | 36 | June 20th, 2007 10:56 PM |
| fuel injectors | scubasteve041186 | V6 Mustangs | 7 | January 24th, 2007 02:44 AM |
