High oil pressure
Old June 25th, 2007, 02:54 PM   #1
burnout5.0's Avatar
2004 Mustang SVT Cobra
448whp/475wtq
burnout5.0 is on a distinguished road
High oil pressure
my '95 5.0 runs high oil pressure, the needle sits at the end of normal on the L its kinda wierd cause the motor is not over filled i drained everything out and put 5 quarts in with a filter change too.... idk what it is maybe the sending unit? input would be great thanks guys.
Old June 26th, 2007, 07:52 AM   #2
FaStStAnG5-0's Avatar
FaStStAnG5-0 is on a distinguished road
Send a message via AIM to FaStStAnG5-0
high oil pressure isn't much to worry about.. plus it's probably just the gauge acting up.. the gauges in our cars suck!
http://www.cardomain.com/ride/2461223
1994 GT: MSD 6AL, BBK O/R H-Pipe, Dynomax Race Bullet mufflers, 3:73 rear, Hurst Short Shifter, MAC cold air intake & much more coming soon!
Old June 26th, 2007, 11:29 AM   #3
burnout5.0's Avatar
448whp/475wtq
very true they do suck... alot. thanks man
MM Cobra Club #78
Old June 26th, 2007, 07:11 PM   #4
Bullitt95's Avatar
1995 Mustang GT auto
13.546 @ 105.32
Bullitt95 will become famous soon enough
The gauge sending unit is probably to blame. If you can get hold of a mechanical pressure gauge, check the pressure with that to see what it really is. Then you'll know if the gauge sending unit is goofy.
243.5rwhp/284.2rwtq
Mod list in My Garage
Old June 30th, 2007, 12:03 AM   #5
burnout5.0's Avatar
448whp/475wtq
found out the problem which could have been fatal.... there are two plugs on the oil pan and one doesn't drain all the oil out and when i got the oil changed they used the wrong plug and there was 2 gallons of oil in the car! which is like 8 quarts.... ill be changing the oil myself from now on.....idiots...
MM Cobra Club #78
Old July 2nd, 2007, 08:41 PM   #6
ahh yes, that might be why..... your average 16 yr. old oil change monkey at jiffy lube probably would never realized your car had a humped oil pan...
Old July 3rd, 2007, 02:10 AM   #7
burnout5.0's Avatar
448whp/475wtq
exactly lol.
MM Cobra Club #78
Old July 3rd, 2007, 06:53 PM   #8
RockerShocker is on a distinguished road
Send a message via Yahoo to RockerShocker
WOW.....Only at Jiffy Lube
Fast, Cheap or Reliable. You get to pick TWO!
Threads Similar to: High oil pressure
How high is too high? silver99gt 99-04 13 October 9th, 2007 07:11 PM
high pressure pump Mustang RacR94 V6 Mustangs 9 September 29th, 2007 06:57 PM
a/c low/high sivart 5.0 Mustangs 1 May 28th, 2007 12:05 PM
To get High or not! Zak 5.0 Mustangs 5 March 30th, 2007 08:30 PM
High Rev jerb43 96-98 3 October 26th, 2006 11:22 AM
