grinding noises?
Old July 1st, 2007, 03:25 PM   #1
blue03mach1 can only hope to improve
grinding noises?
i have a tremec 3500? in my 95 gt and sometimes when i shift while racing.. it will make a grinding noise.. i no i have the clutch down all the way and sometimes when i power shift.. is this hurting the tranny? its mostly 3rd gear that does this.. thanks for any info
Old July 1st, 2007, 03:41 PM   #2
burnout5.0's Avatar
2004 Mustang SVT Cobra
448whp/475wtq
burnout5.0 is on a distinguished road
powering shifting is great in a race but not so great on the tranny and grinding noises from a tranny usually arent to good either...
MM Cobra Club #78
Old July 1st, 2007, 03:45 PM   #3
well ive been told.. that tremec 3500 is pretty tough and it can take a lot.. so i dont no, is there any way i can check or tell if it is damaged? or will i just have to get the whole tranny looked at?
Old July 1st, 2007, 03:58 PM   #4
burnout5.0's Avatar
448whp/475wtq
well im no expert but you could change the oil and see if there are any metal shavings in the oil that would show signs of gears being worn excessively or go to a tranny shop they can tell you probably just by driving the car if they know what they are talking about, just don't let them rip you off.
MM Cobra Club #78
Old July 3rd, 2007, 06:57 PM   #5
RockerShocker is on a distinguished road
Send a message via Yahoo to RockerShocker
Might be a clutch going. Especially if its all the way in when shifting. At least thats the cheap answer. Only other way to tell is tearing into the trani. So you pick the answer that you can afford. And dont power shift, your talking at most .2 off the quarter. I dont think that is worth a trani.
Fast, Cheap or Reliable. You get to pick TWO!
Threads Similar to: grinding noises?
transmision noises El_Cangri V6 Mustangs 22 April 6th, 2007 02:14 PM
Clicking Noises modded232 V6 Mustangs 11 April 6th, 2007 02:09 PM
Grinding and Popping Noises wilburgtwoot General Tech 0 February 8th, 2007 05:57 PM
Front end NOISES! 96mystic Modular Mustangs 4 February 8th, 2007 05:15 PM
Noises... Stan27 General Tech 20 June 22nd, 2006 03:06 AM
