Water Temperature
Old July 8th, 2007, 06:46 PM   #1
burnout5.0's Avatar
2004 Mustang SVT Cobra
448whp/475wtq
burnout5.0 is on a distinguished road
Water Temperature
Does anyone know where my '95 5.0's water temperature is supposed to run normally? No one seems to know, any input would help. thanks guys.
Old July 8th, 2007, 07:28 PM   #2
TENGRAM is on a distinguished road
Re: Water Temperature
190-200º
89 GT t5 3.73
www.my5oh.com/
Old July 9th, 2007, 02:51 AM   #3
burnout5.0's Avatar
448whp/475wtq
cool thanks
MM Cobra Club #78
Old July 9th, 2007, 03:43 PM   #4
Bullitt95's Avatar
1995 Mustang GT auto
13.36 @ 105.0
Bullitt95 is on a distinguished road
Originally Posted by TENGRAM
190-200º
Good answer but since the gauge isn't graduated in degrees, any Mustang noob isn't going to have a clue where 190-200*F lies on the gauge. I think I have the answer though.
I tried to determine the actual coolant temp. at various points on my gauge by taking resistance readings across the wires going to the ECT. By extrapolating the temp. from the resistance (in ohms) I was able to determine that:
Low speed fan on = Needle on M of NORMAL = 208*F
Low speed fan off = Needle between O and R of NORMAL = 198*F
Therefore the middle (between R and M) equals 205*F and each letter adds or takes away 7*F:
Needle just below N = 184*F
Needle between N and O = 191*F
Needle between O and R = 198*F
Needle between R and M = 205*F
Needle between M and A = 212*F
Needle between A and L = 219*F
Needle just above L = 226*F
The stock thermostat opening temp. is 192*F. In a cool climate, the gauge should sit at or around the t'stat opening temp. during a highway cruise, so that's between N and O. In hotter climates the gauge will read higher but still shouldn't be above halfway unless conditions are extreme and you've got the AC on.
244whp/284wtq
Mod list in My Garage
Old July 9th, 2007, 05:12 PM   #5
burnout5.0's Avatar
448whp/475wtq
wow thats really helpful thanks
MM Cobra Club #78
Old July 9th, 2007, 06:07 PM   #6
Bullitt95's Avatar
13.36 @ 105.0
For those who like metric units, the conversion will be as follows:
Needle just below N = 84*C
Needle between N and O = 88*C
Needle between O and R = 92*C
Needle between R and M = 96*C
Needle between M and A = 100*C
Needle between A and L = 104*C
Needle just above L = 108*C
Threads Similar to: Water Temperature
AutoMeter transmission temperature gauge knightster420 V6 Mustangs 3 August 17th, 2007 11:32 PM
temperature gauge issue 2004GT Audio/Video 2 May 13th, 2007 09:54 PM
Temperature Gauge lwhitetrash88l V6 Mustangs 4 April 14th, 2007 11:06 PM
water in gas 2004GT 99-04 4 February 19th, 2007 03:01 PM
1995 Mustang V6 temperature issues I_CTCHR95 V6 Mustangs 1 November 5th, 2006 10:43 AM
