What Type of Cam Should I Go With?
Hi everybody, I'm new on the forums. I needed help getting a SMOG LEGAL Cam that will give me a broad power range. My current set-up is a 5.0 stock bottom end with Trick Flow Street Heads/Manifold, full exhaust, cai, 24lb injectors.
I'm not supercharged yet, more worried about passing smog in CA. I had a Stage II TFS Cam that is not smog legal if anyone is interested |
My advice to you is to call up Comp Cams or Lunati or whoever you want and talk to someone in the cam help department. Those people do cams for a living so they know exactly what they are talking about.
check out AndersonFordMotorsports.com ,they can make you a custom grind cam that would be smog legal and work well with a SC.the E-303
is a smog legal cam that works well with boost but the design is a little dated
You could go for the TFS Stage 1 cam if the engine's staying naturally aspirated. If you're going to supercharge, you could consider the Steeda 19 blower cam.
![]() 244whp/284wtq Mod list in My Garage |
make sure you check your VALVE CLEARANCE .... i was going to go trick flow with my 331 but you have to buy their pistons and stuff for the set up i wanted then the stuff you didnt need pistons didnt put the kinda power down i wanted .. i went edelbrock for same money and more hp better quality
#6 | ||
88Notch 10.59 @132 / 03 Mach 1 13.1 @104
E303 OR trickflow Stage 1
Military Crew USMC
Threads Similar to: What Type of Cam Should I Go With?
| Which type of gas do you use? | 00GT MuscleBlack | V6 Mustangs | 23 | November 1st, 2011 05:57 PM |
| 5.0 HO Oil Type? | poisonstallion95gt | 5.0 Mustangs | 56 | September 22nd, 2007 11:37 PM |
| Which type of gas do you use? | 00GT MuscleBlack | 99-04 | 21 | July 30th, 2007 12:21 PM |
| type oil in 50 | cobralini | 5.0 Mustangs | 0 | August 14th, 2006 03:48 PM |
