RUNNING HOT!!!!!!!
HELLO PEOPLEZ I COULDNT FIGURE IT OUT SO I KNOW I CAME TO THE RIGHT PLACE! MY AUTOMATIC GT IS NOT OVER HEATING BUT SHES ALWAYS RUNNING HOT IN BETWEEN THE M AND THE L LIKE RIGHT ON A AND MY UPPER HOSE GETS REALLY HARD AND HOT I HAVE NO LEAKS OR ANYTHING! ANY SUGGESTIONS GREATLY APPRECIATED THANKS!!!!
have you chased A FORD LATELY? |
2004 Mustang SVT Cobra
448whp/475wtq
its getting hard and hot because the cooling system builds pressure so thats ok nothing to worry about, but mine runs in the same area between the M and L (which is about 220 Degrees) ive yet to figure it out too... sooo maybe someone else will be able to help us.
MM Cobra Club #78 |
RUNNING HOT!!!
SWEET THANKS FOR THE INFO, I WAS BEGINNING TO WORRY! MAYBE SOMONE WILL GIVE US ANOTHER OPINION...THANKS!
448whp/475wtq
yeah hopefully because its still running too hot the normal temp its supposed to be at is between 190 and 200 so its still at the least running 20 degrees too hot...
MM Cobra Club #78 |
I'm in the same boat and I'm not even running a thermostat, but here it's 115*F outside so that comes as no surprise. I think the stock radiator is marginal at best and when the weather's hot, it just can't cool the engine enough. I'm planning to replace mine with a Mishimoto aluminium unit.
![]() 243.5rwhp/284.2rwtq Mod list in My Garage |
448whp/475wtq
Yeah i think its a pretty common problem on our cars. and hey, Bullitt95 did it help at all when you took the thermostat out??? cause if it did ill pull mine too
MM Cobra Club #78 |
RUNNING HOT!!!!!1
FOR SURES I PULLED MINE OUT AND IT DID HELP BUT NOT ENOUGH
TO MAKE IT RUN COOLER, WHAT DO YOU GUYS THINK OF FLUIDYNE RADIATORS? I WAS THINKING OF GETTING ONE BUT I DONT KNOW ANYTHING ABOUT THEM!? HAVE YOU GUYS HEARD ANYTHING GOOD FROM THEM?
448whp/475wtq
i was just comparing the mishimoto and the fluidyne radiators i don't know anything about either of them but they both say the cool 20-25% better than stock but the fluidyne is about $200 more than the mishimoto.
MM Cobra Club #78 |
RUNNING HOT!!!!
COOL I GUESS I HAVE TO GO WITH THE MISHIMOTO BECAUSE IF THEY DO THE SAME THING AND I SAVE 200 BUCKS THATS MY GEARS RIGHT THEIR.
WHAT GEARS WOULD YOU GUYS SUGGEST FOR MY AUTO GT?
Make sure your fan is working properly. Make sure the temp gauge is accurate. Make sure high speed and low speed on the fan are coming on at the right temps. check both temp sensors. Dont take the thermostat out. It is there to help the computer control the engine properly. If all those things are correct. Try bypassing the heater core. Mine had a pinhole in it. It never leaked. What it was doing was allowing air into the system and therefore the flow was screwed up. The leak was only evident if you turned on the defroster. You will also find a haze on the inside of the windshield. So clean your windshield and turn on the defroster. If it becomes hazy, smells like coolant or fogs up the windshield, replace the heater core. Hope this helps.
#11 | |
My low speed fan comes on at 208*F but the high speed doesn't work when I operate MAX AC. The only time the high speed fan does work is when the gauge is almost in the red. I'm going to wire up a manual switch for it by grounding the wire to CCRM pin 17. My gauge seems to work fine; 208*F corresponds to the M and the 198*F fan off temp. is between O and R. |
RUNNING HOT!
SWEET I WILL DO THAT! THANKS GUYS! ANY SUGGESTIONS ON MY REAR END GEARS? ITS A AUTO GT 5.0! 373 OR 355 OR 410 AND A ALUMINUM DRIVE SHAFT WILL ALL THIS MAKE A DIFFERENCE?
448whp/475wtq
I would say run a 3.73, they are the most popular. it makes a big difference and your car won't rev really high when your on the highway. 4.10s are a little low i think
MM Cobra Club #78 |
RUNNING HOT
ARE THEY HARD TO INSTALL?
448whp/475wtq
ive never done it before i think it would just be easier to bring it to a mechanic and have them do it. or find a write up online that shows you how to do it yourself.
MM Cobra Club #78 |
RUNNING HOT
COOL!
#17 | |
Re: RUNNING HOT
448whp/475wtq
lol yeah very true
MM Cobra Club #78 |
99 SVT Cobra
N/A Yet
![]() iTrader: 1 reviews
Dont do the gears yourself if u have never done them....take it toa mechanic
Mods iN Garage.:.919 of 4040.:.Born on 3/29/99 Found On Road Dominating |
RUNNING HOT
COOL GUYS THANKS FOR THE 411!
Threads Similar to: RUNNING HOT!!!!!!!
| Got Her Running, But wont stay running...help? | Speedstang302 | 5.0 Mustangs | 10 | August 28th, 2011 05:58 PM |
| 95 GT Running Very Hot | JesusOnIceSkates | 94-95 | 14 | November 13th, 2007 04:57 PM |
| not running right | jkovacs60 | General Tech | 2 | August 3rd, 2007 02:13 AM |
| Bad running... | alabamastanger | 5.0 Mustangs | 4 | July 15th, 2007 06:25 PM |
| Just Got Done Running a 89 LX 5.0 | Bigb2000GT | 99-04 | 1 | March 19th, 2007 06:57 PM |
