Car Dies While Driving (Help!) TFI?
Old August 9th, 2007, 05:12 PM   #1
bigred2k is on a distinguished road
1995 Mustang GT 43k miles
After searching the net my symptoms sound EXACTLY like a TFI module problem.
After anywhere between 10-30 minutes of driving my voltmeter on the dash will start "bouncing" back and forth slightly and I can see that there is voltage irregularities by looking at a voltmeter that is mounted in my trunk.
After awhile of this erratic behavior the car will just die. Like it loses power completely. Normally it doesnt start back up immediately but requires anywhere between 5-10 minutes then it will start up and run find again.
I stumbled across this site (www DOT coolcats DOT net/tech/troubleshooting/tfi.html) and it shows only the following years effected by the tfi recall
1984-89 Mustang/Capri (2.3L)
1984-86 Mustang SVO TC (2.3L)
1984-86 Mustang/Capri (2.3L)
1984-85 Mustang/Capri (3.8L)
1984-94 Mustang/Capri HO (5.0L)
It should be noted that I have checked the alternator and battery and both are delivering the correct voltage.-
Can anyone offer any insight? I would GREATLY appreciate it as I just started a new job and getting to work reliably and on time is important to me right now.
Old August 10th, 2007, 01:40 PM   #2
95opal's Avatar
95 opalfrost gt
95opal will become famous soon enough
Sounds like it could possibly be the TFI, they have a tendancy to get heat soaked and crap out. When this problem occurs you need to verify injector pulse to eliminate the possibility of a faulty PIP sensor. From what ive seen and dealt with is if it suts off and restarts after it cools down then most likely its the TFI, but like I said earlier verify injector pulse.
5.0 magazines
94-04 performance mustangs feature car! Fall 2010
Old August 10th, 2007, 03:05 PM   #3
lugthug713's Avatar
2002 Roush 360R
lugthug713 is on a distinguished road
mine did that and it was the little sensor inside the distributor
Old August 15th, 2007, 07:40 PM   #4
Clever Minx's Avatar
Clever Minx is on a distinguished road
WOW
I Posted a question just about like this one The fellas gave me ALOT of helpful tips.
Maybe some of their answers for me can help You.
http://www.moddedmustangs.com/forums...e6edacb0888565
Im about to change my TIF
Old August 24th, 2007, 02:12 PM   #5
Re: WOW
Did this solve the problem? Also....When you exeperince this problems does the voltmeter on the dash fluctuate back and forth slightly?
Threads Similar to: Car Dies While Driving (Help!) TFI?
my mustang dies.... RhadCundell V6 Mustangs 22 November 30th, 2010 05:21 PM
dies at 3k superman5.0 5.0 Mustangs 7 July 18th, 2007 05:26 PM
Starts and Dies RDR61 5.0 Mustangs 4 July 4th, 2007 10:11 PM
Car dies out Espo General Tech 1 August 22nd, 2006 01:21 PM
Engine Dies While Driving Mystic Mama 96-98 7 May 6th, 2006 07:55 PM
