XFI Stroker Cam
Old August 20th, 2007, 12:40 PM   #1
Euroeater95 is on a distinguished road
XFI Stroker Cam
Has anyone used or know somebody that used the Comp Cams XFI Stroker cam? If so how does it perform and did they have any issues with it?
Old August 25th, 2007, 11:26 AM   #2
Justincredible's Avatar
Justincredible is on a distinguished road
No I havent.
With that said....for just a few dollars more...why not go ahead and let Comp grind a custom cam for your application, instead of using an "off the shelf" cam.
9.91@ 134mph 1/4 - 6.17@ 109mph 1/8th - 1.33 60' - Stock ECU & Stock Suspension......and getting faster .
BIVENS RACE CARS FTMFW!!!
Old August 27th, 2007, 01:19 PM   #3
Well I called the cam help hotline and that is the one that they recommended I use. I was just wondering if anyone has used this cam before, because my engine builder said he wouldnt run it. I talked to Comp cams again and they said that the powerband will be from 2600 to 7600 and I think that a powerband like that is perfect. They did say that it might be lazy from 1500 to 2600 though.
Threads Similar to: XFI Stroker Cam
Stroker Kit 101 scxc15 V6 Mustangs 5 November 4th, 2007 01:46 PM
To Stroker or Not to Stroker? That is the Question! 87StangLX General Tech 13 October 20th, 2007 11:46 AM
347 stroker mustang_s 96-98 2 August 7th, 2007 11:57 AM
347 stroker 2007calispecial 5.0 Mustangs 8 July 31st, 2007 08:55 PM
331 stroker ballzout 5.0 Mustangs 8 July 20th, 2007 05:59 PM
