Discussing spool or locker? in the 94-95 Forum. if i was gonna put a 3.73, trick flow stage 2 cam, p&...
Old August 29th, 2007, 05:32 PM   #1
94pacecarSVT's Avatar
11.2@122.36
spool or locker?
if i was gonna put a 3.73, trick flow stage 2 cam, p&p'd 351w heads, and new headers on my car, i was thinkin complete that badass setup with a badass diff. and get a spool. but then i figured id be breakin shit left and right...or crashing in the rain. so which do you guys suggest, spend less and get a spool, or spend more and get a locker?? thanks.
black 96 gt w/ 00 gt motor, procharger p1sc 11lbs intercooled. comp cams xe274h .500 lift, full bolt ons, full tubular/alum. susp. w/ coil overs. 4 pt. roll cage. more pic and full list of mods in garage.
www.rk-collection.com
Old August 30th, 2007, 06:04 AM   #2
HMUSN's Avatar
91 Sonic Blue Goodness
19.83 @ 12mph
don't get a locker... you don't need it.
it's too rough of a ride for a street car.
Old August 30th, 2007, 06:03 PM   #3
Justincredible's Avatar
I love my Moser spool.
But if its going to be a daily driver, id think about other options, due to the fact that they do chew up tires and put alot of stress on the rear suspension mounting points.
Lockers work great...but they are loud and obnoxious on the street.
9.91@ 134mph 1/4 - 6.17@ 109mph 1/8th - 1.33 60' - Stock ECU & Stock Suspension......and getting faster .
BIVENS RACE CARS FTMFW!!!
Old August 30th, 2007, 06:41 PM   #4
11.2@122.36
yea my buddy has a locker and every time he turns it sounds like broken spider gears. but if i were to get a spool, (seeing as to how they are much cheaper, thats probably what i would want.) what would you suggest i do to make my rear end and rear susp. stronger so i wont break anything? and if anyone knows of a decent locker that isnt super expensive, please lemme know. thanks.
Old September 2nd, 2007, 03:07 PM   #5
I can tell you what my setup is...but keep in mind...it sees very limited street use.
Moser 33 spline axles
Moser c-clip elems.
Moser Spool
Richmond solid pinion spacer
Base Line Level 2 uppers
UPR solid bushing lowers
Custom made axle tube braces (to prevent bending the axle housing/tubes)
Reinforced and welded up upper and lower torque boxes with extra metal added to the bolt hole mounting points to prevent ripping out the bolt holes.
Threads Similar to: spool or locker?
Do you have a locker? 06VistaBlueGT 2005+ 3 October 3rd, 2007 05:45 PM
Several men are in the locker room WAR-PARTY The Clubhouse 19 September 20th, 2007 10:06 AM
locker or trak lok Iownastang 5.0 Mustangs 8 September 6th, 2007 12:50 AM
posi or locker Badasstang281 99-04 8 April 25th, 2007 05:39 PM
Spool HILLBILLY32V 5.0 Mustangs 5 July 18th, 2006 12:50 AM
