cooler thermostat?
a friend recomened putting a cooler thermostat in my stang because its been running hot. i had a problem with the thermostat hangin up and causing the car to overheat really fast, so i replaced it. this was about a month and a half ago maybe. two days ago i was drivin and it over heated again, but this time my antifreeze was boiling and spewing out of the resovoir...and yesterday i drove it and it was fine for the most part. any help would be appreciated...im not driving it with it like this because i dont have the money to replace a motor, so if any one knows please tell me. thanks.
black 96 gt w/ non pi motor, cai, built t45, built rear end w/ 3.73's, completely modded suspension, race radiator.....startin over.www.rk-collection.com |
Antifreeze boiling up and spewing out of the reservoir could be a sign that you have a bad radiator cap that's not holding pressure. With less pressure in the cooling system, the coolant boils at a lower temperature.
Buy a new 16psi radiator cap. That's a cheap fix 4U.
![]() 243.5rwhp/284.2rwtq Mod list in My Garage |
2004 Mustang SVT Cobra
448whp/475wtq
same thing happened to me it was a bad cap and i replaced it and for the over heating make sure fan is turning on mine overheated due to a bad coolant temperature sensor which is what tells the fan to turn on. mine still runs about 20 degrees too hot but it hasn't overheated since i replaced that sensor.
Have you had it at a shop within the last month?
no..the last time it was overheating/ heating up extremely fast, i replaced the thermostat myself, and i did the same this time...it helped, but i need to have the car looked at. when im drivin at around40-60 mph itll have like little "spasms" where it cuts out and back in really quickly. i notice it more with cruise control on then with it off, but idk..i was thinkin maybe a bad plug or injector...what do you guys think?
Threads Similar to: cooler thermostat?
| Our Sigs Are Cooler Than Yours | Drick | The Clubhouse | 39 | November 10th, 2007 10:25 PM |
| cooler | mpboy | 99-04 | 3 | October 15th, 2007 10:52 PM |
| Transmission Cooler? | Garhfer | 99-04 | 1 | September 15th, 2007 02:02 PM |
| Anybody running a cooler thermostat, aluminum DShaft | RStrick0352 | 2005 - 2010 | 14 | May 25th, 2007 07:12 AM |
| Transmission Oil cooler | Mustang Mike | 99-04 | 1 | March 5th, 2007 09:41 AM |
