1995 Mustang GT
torque converter problem?
i have a 95 5.0 and i was told that my torque converter is locking up and causing a vibration in the rear as it is shifting. i have a stock automatic trans with a shift kit. any ideas?
you probly just suck!
95' GT is being reconstructed! |
![]() iTrader: 1 reviews
how bad can it be if your suck at automatic?
Giving Away For FREE PM ME. FREE 351 Block, 90,xxx miles (Non roller block) FREE 94-98 GT Hood (red) |
it could be possible if it causes the engine to lug.also check your driveshaft
for any weights that fell off
#5 | |
oh and 95stangvert we'll look at it this weekend
#6 | |||
1995 Mustang GT
dude i asked a question, if you dont want to help leave it alone
#8 | |
haha... dude dont get you're panties in a bunch...what i was saying to you is the way you typed your sentence did not make sense and yes if you dont mind rephrase the first thing you said...
also he is my friend and i just thought i'd give him a hard time on his first post! THANK YOU
Might just be time for a new converter...With that shift kit, you should be running a trans cooler too...Nice cheap mod to help with the trans...
This transmission shuddering is known problems:
This internet thing is wonderfull Try some googling and you will find almost anything :-D ----quote---- The shudder during 3-4 lockup is a breakdown of the oil-friction interface at the clutch in the converter. This breakdown is caused by oil type, temperature (put on a cooler), and energy (or calibration). This breakdown causes the shudder. For the sake of your car you should get the cooler, mercon V and new calibration that is recommended in the TSB. With all 3 of these, you will most likely not get shudder again. Reverse shudder is an alignment problem with the gear set. The gear set is aligned on 3 bushings. These 3 will "fight" each other causing a light throttle shudder. This doesn't hurt anything, and usually goes away with miles. The older torque converters (trans's built before 10/94) or Mark 8's and Mustangs up to '97, are a less "optimal" design. The converters built after this point are good. The difference is the stiffness of the lock up plate and the radius of the friction material. Tips: Anyone who owns a AOD, AODE or 4R70W transmission it is very important that you replace your 1-2 accumulator ASAP! They like to go bad. It was part of a TBS and thus not required by Ford to recall all AOD and AODE transmissions. Reason: Aluminum style wears out the case and burns up the 2nd clutch. 1-2 accumulator piston changed from aluminum to molded rubber. (Updated molded rubber style) F7AZ-7F251-AA. (See picture) Recommendation: Always update to the rubber accumulator. If the bore is worn in your case you can salvage it by Scothbriting the bore real good and installing the rubber piston. Only after 40K on my transmission visable signs of wear showed on the aluminum acvisibleor and bore it fits into. If not replaced a rebuild or worse a new case would have been necessary. You do not have to remove the valve body to access the 1-2 accumulator. After you remove the transmission pan the accumulator is held in place via a snap ring in the drivers side upper corner of the case. ----quote---- Br. rru |
1995 Mustang GT
thanks for the good info, i appreciate it
1995 Mustang GT
i ended up using a trans additive that fixed whatever was happening
Threads Similar to: torque converter problem?
| torque converter | 06Stanger | 2005 - 2010 | 0 | July 29th, 2007 11:16 AM |
| Installing a Torque Converter?? | MustangJon255 | 2005 - 2010 | 1 | July 15th, 2007 03:06 PM |
| torque converter | barksdaleammo | 99-04 | 5 | April 3rd, 2007 06:20 PM |
| Torque converter for our cars | JASonic | V6 Mustangs | 21 | March 5th, 2007 01:51 AM |
| Torque Converter ? | BraggStang | General Tech | 5 | August 11th, 2006 06:57 AM |
