Discussing 94 gt/ cobra clone problems... in the 94-95 Forum. I have a list of add-ons, and with it a small annoying problems as ...
Old October 4th, 2007, 12:17 AM   #1
Look Ma! My First Post!
I have a list of add-ons, and with it a small annoying problems as well...
"Were do I start....
I purchesed the car for a guy in Florida , and he told me it has a 347 cu.in. motor, with Edlebrock performer heads and a "E" 303 cam. It has a gt40 intake with a 70mm throtle body and a 73 C&L mass air meter. I also have 30 pound injectors 1.7 roller rockers MSD billet distributor, MSD6a, and blaster2 coil.
AODE transmission, 355 gears
When I bought it, he told me it just needs to be "TUNED", and I figured easy..no problem.....
I took it to a performance shop in Houston and had a SCT chip installed and tuned...and the problem started!!!
...The car starts good..idles ok(when cold) but if you turn it off, and try to restart it it has a hard time holding a idle when put into gear...
..Also when I had it tuned , the guy tuneing the car said he started out tuning it at 10 degrees but had ALOT of detonation..so he pushed it back to 8 degrees...and it is still "Pinging" alittle under full throtle....and the tuner said it "MIGHT" have 11:1 compression....but I dont think this is true???I am going to check for high cranking compression to maybe see if the cam is degreed wrong...ANY OTHER IDEAS?
Old October 4th, 2007, 07:58 AM   #2
Bullitt95's Avatar
1995 Mustang GT auto
13.87@101.3
It's quite possible that the static compression ratio really IS that high because stroking the engine increases the CR. If the cam's intake duration is too short or the intake valve closes too early, the dynamic compression ratio can be so high that detonation occurs even on premium fuel with retarded ignition timing.
I think you're on the right track in checking the cranking compression in each cylinder. If it does turn out to be very high (over 190psi), retarding the cam will help the situation some.
Mod List
Old October 4th, 2007, 01:36 PM   #3
Timm10221's Avatar
Location: Stationed in Jacksonville, NC ; Home Town PSL FL
yea i agree^.... and make sure you are runnign 93. I would think the tune would of made her run right but yea check all the normal things too like plugg gaps and crap...
Military Crew USMC CPL
1995 Mustang GT
Originally Posted by JBIGBOOTSY
I usually kill the hookers(so I don't have to pay them) then I take their hands for my collection.
Originally Posted by homebrewed
Perversion mixed w/ mild tech... God I love ModdedMustangs!!
Threads Similar to: 94 gt/ cobra clone problems...
Cobra clone? JAY'SRED02 2005+ 25 October 15th, 2007 09:47 AM
Looking at 03 Cobra to buy. Any problems I should look for? Areteracing 99-04 39 April 15th, 2007 02:19 AM
Making a 93 clone.... BravoTeamLeader 5.0 Mustangs 7 December 11th, 2006 07:48 PM
Problems with my 99 cobra 99SVTCobra 99-04 0 November 8th, 2006 03:21 AM
03 and 04 Cobra problems? x.Ln 99-04 2 August 6th, 2006 11:33 PM
