Discussing cam install in the 94-95 Forum. i read the newbies first bolt-on mods post and i have been considering getting new ...
Old October 10th, 2007, 10:13 PM   #1
cam install
i read the newbies first bolt-on mods post and i have been considering getting new cams. i got a 95GT that I eventually want to supercharge. what cams do you guys recommend and what type of install job will i be looking at? should i have a professional do it?
Old October 10th, 2007, 10:58 PM   #2
You only have one cam dude, not "cams"
Choosing a camshaft determines alot on what your setup is composed of. what are your mods?
Old October 11th, 2007, 12:29 PM   #3
installing a cam with stock heads and intake will not do much in horsepower.you could use an e cam from ford motorsport its not the most advanced but still gives you a good idle and works well with a blower.there are other cams but dont choose something to big or you will have a bad idle or you will shift your power up too high in the rpm range also spring bind or bending valves due to piston contact if you are using stock heads.you probably should have a pro do the install if you are not familiar with the engine
Heres a real funny video
youtube.com/watch?v=ojB7KkaR03I
VTEC stands for Very Torqueless Economy Car
Honda stands for Hold On Not Done Accelerating
1991 LX 5.0 H/B(T-70 turbo coming soon)
Old October 11th, 2007, 03:03 PM   #4
i have shorty headers and a CAI. i want to get a TFS intake and a 75mm throttle body.
so you guys say heads before cam? and i knew i only had one cam, idk what the hell i was thinking by saying "cams" . lol
any suggestions on heads keeping in mind future supercharging plans?
Old October 12th, 2007, 01:56 AM   #5
Not so much heads before cam, alot of people do heads, cam, and intake at the same time.
I would say any decent off the shelf aluminum head would work well with a blower. Depending on how much boost you want to run, and how much HP you will be pushing will determine how big of a head you want. 165, 185, 105, 225, etc. Look into one of the TFS top end kits, or maybe some AFR heads matched with a good intake. Edelbrock makes good stuff too.
As for the cam, you should definitely hold off. Like stated above, it wont really do anything for you, except give you a thumpy idle.
Say you get the TFS top end, you could either get one of their cams, or get a custom blower cam for it...The custom would max out performance, driveability, and just suit your setup very well.
Threads Similar to: cam install
How to Install a Top TurboLX Convertibles 4 September 19th, 2008 11:37 PM
*^$ HOW DO I INSTALL *^$ mustang1072 V6 Mustangs 4 September 27th, 2007 11:45 AM
CAI install jabrennan V6 Mustangs 22 March 10th, 2007 02:30 AM
sub and amp install GreenFaleen Electronics 17 January 4th, 2007 12:40 PM
HID install help geekstang 99-04 1 August 26th, 2006 04:17 PM
Forum is powered by vBulletin ©2000 - 2010, Jelsoft Ent. Ltd. & SEO by vBSEO 3.3.2 ©2009, Crawlability, Inc.
