95 cobra engine numbers?
Old October 20th, 2007, 07:45 PM   #1
5.0 kid's Avatar
5.0 kid is on a distinguished road
Send a message via AIM to 5.0 kid
Im new to this site and i was wondering what kinda of numbers a 95 5.0 cobra engine will put out with ford racing headers, bbk u/d pulleys, bbk cold air intake, trick flow intake manifold, and a 75mm throttle body. i own a 91 lx convertible and im going to put that engine in because my brother fried my original 5.0
Old October 21st, 2007, 06:52 AM   #2
JohnC's Avatar
1997 Mustang GT
13.56@102.94
JohnC is on a distinguished road
They were rated at 240hp at the crank, right? I'd just guess about 255-265rwhp?
I have no clue honestly. Strap it on a dyno when you get the motor in and keep us posted on the dyno results.
1997 Mustang GT
Aluminum Block PI swap & 4R70W to TR3550 swapped.
Best 1/8: 2.04 60ft 8.74@81.85 &
Best 1/4: 2.045 60ft 13.56@102.94
all on stock 245-17's
My Garage
Old October 21st, 2007, 07:48 AM   #3
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
That is probably about right. 255 to 265hp at the flywheel though, not at the wheels. Probably gained 8hp from the pullies, 10hp from the intake, 10 from the headers if they are long tube headers and lost about 3 or 4 from the 75mm throttle body. That puts it right around 264-265hp.
Old October 22nd, 2007, 11:59 PM   #4
5.0 kid's Avatar
what would yall suggest i put on for a real power boost. ive got about 3500 dollars ive put back for such an occasion haha. ive heard alot about stroker kits and such, then there is always the turbo/supercharger debate.
Old October 23rd, 2007, 12:06 AM   #5
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
A good set of cylinder heads.
Old October 23rd, 2007, 12:24 AM   #6
5.0 kid's Avatar
sooooo say trick flow twisted wedge heads???? or tha dart aluminum heads?
Old October 23rd, 2007, 08:47 AM   #7
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Trick Flow, Canfield, AFR, etc.
Old October 23rd, 2007, 11:35 AM   #8
Bullitt95's Avatar
1995 Mustang GT auto
13.546 @ 105.32
Bullitt95 will become famous soon enough
They were indeed rated at 240hp at the crank but some will say that the Cobra should have been rated at 250-255hp crank given that they're putting down about 215-220 at the wheels.
With those mods I'd say you could be right at 265rwhp, and there's no way the 75mm TB will cause a 3-4hp loss (more likely that degree of gain instead).
I suggest you port the existing Cobra GT40 heads / Cobra intake, and swap in a Steeda 19 cam. It'll give you a combo that'll deliver abundant midrange torque and still pull well up to about 5700rpm.
243.5rwhp/284.2rwtq
Mod list in My Garage
Old October 23rd, 2007, 11:47 AM   #9
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
What is your basis for saying "there's no way the 75mm TB will cause a 3-4hp loss"? Do you have any data to back this up? I've seen large throttle bodies lose horsepower on stock to mild engines. The throttle body is one of the last things you would upgrade on a 5 liter.
Old October 23rd, 2007, 08:06 PM   #10
5.0 kid's Avatar
tell me more about tha 19 cam and how i would go about
getting one.
oh and the reason for the 75mm T/B
is because the BBK 65mm T/B that was on when
i got tha engine was cracked
Old October 24th, 2007, 08:35 AM   #11
Bullitt95's Avatar
13.546 @ 105.32
True that you don't need to upgrade the TB on a 5.0 until you've done quite a few other mods, but I haven't seen a dyno test that has shown a HP loss by upgrading to a larger TB on even a mild 5.0. Then again, not much of a gain either.
I have a 75mm TB on my own 5.0 and while it didn't alter WOT performance, there was a noticeable improvement in part-throttle response compared to the stock 60mm TB.
I'll agree with your last statement but I would say that if one does decide to upgrade the TB, it would be a waste of money to go to 65mm only to find out later on that you should have got a 70 or 75mm unit. Better to upgrade only once.
Old October 28th, 2007, 01:58 PM   #12
5.0 kid's Avatar
do yall think LS6 heads would fit on a 95 cobra engine?
Old October 28th, 2007, 07:31 PM   #13
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
This is just one example...
Old October 28th, 2007, 07:32 PM   #14
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
You can't be serious....
Old October 28th, 2007, 07:52 PM   #15
07gtmustang's Avatar
2007 GT
07gtmustang is on a distinguished road
+1
Old October 29th, 2007, 03:43 PM   #16
Bullitt95's Avatar
13.546 @ 105.32
The difference between all the TBs is so insignificant you're splitting hairs. What it does show is that the stock TB is adequate at that HP level under WOT, but what it doesn't show is how a larger TB can improve part throttle response and that's something you can't measure on the dyno.
Old October 29th, 2007, 10:10 PM   #17
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
The bigger throttle bodies lost power across the board in that example. A bigger throttle body isn't going to improve response, just like bigger carburetor venturis won't. Its very rare that to find a part that will lose power across the rpm range (especially low end) and improve throttle response. However there could be an improvement in response in the design and quality of a throttle body such as an Accufab model over the factory throttle body.
Old October 29th, 2007, 11:14 PM   #18
5.0 cobra's Avatar
5.0 cobra is on a distinguished road
those are some nice slips
where did you get those?
i hope your kiddin about tha ls6 heads
GO FAST.... or be a tuner
Old October 30th, 2007, 09:36 AM   #19
Bullitt95's Avatar
13.546 @ 105.32
The power "loss", where there was one, was less than 2% at worst and the HP/TQ numbers were within 1% over almost the entire rpm range. The difference is statistically insignificant and is within a dyno measurement's margin of error.
Secondly, throttle bodies don't behave like carbs. A carb has to mix fuel with air so if the carb is too big, the airflow velocity falls and the fuel can drop out of suspension, causing a power loss. Throttle bodies only have to regulate airflow into the intake manifold so a bigger TB won't cause power loss. A TB that's too big will, however, cause the vehicle to jerk at small throttle openings if you're crawling in slow traffic, which can be a real PITA if you have to keep riding the clutch pedal to keep things smooth.
I went from the stock 60mm TB to a 75mm unit on my Stang, and I can tell you that part throttle response improved enough for me to feel it by the seat of my pants. I can accelerate at the same rate with a much smaller throttle opening and with less pressure on the gas pedal. You'd have to try it yourself to know what it feels like but if you ask me whether I'd prefer to have the 60mm or the 75mm TB, my answer will definitely be the 75.
243.5rwhp/284.2rwtq
Old October 30th, 2007, 12:21 PM   #20
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
If you want to spend the money on a throttle body on a stock or mild engine, go ahead. After all its your money. The issue has nothing to do with injecting fuel. A bigger carburetor flows more air, not more fuel. A bigger venturi will kill throttle response and power if the engine doesn't require the increased volume. Airflow 101. If you are indeed honestly seeing an increase in throttle response I'd bet it is due to the better design of the throttle body, definitely not the size. I went from a 70mm to a 65mm on my 91GT and had a minimal gain in power across the board but no gain in peak power. At the track the car went over a tenth quicker with the 65mm throttle body. As far as having to try it myself, I've probably swapped out more throttle bodies, intakes, cylinder heads than everyone on this site combined. Like I said, I've seen bigger throttle bodies lose power on a dyno and I'm not the only person either. I've never seen anyone say they've seen power gains on a stock to mild engine by going to a bigger throttle body.
Threads Similar to: 95 cobra engine numbers?
which engine for 1500 rwhp 2003 cobra 1999 cobra or 2000 gt gtjason New Members Introductions 14 February 19th, 2012 09:19 PM
Horsepower numbers.......engine was dynoed today 1slo5.0 The Clubhouse 22 August 26th, 2007 12:18 AM
no ECU with cobra engine? Invictus 99-04 3 April 2nd, 2007 08:26 AM
04 cobra engine FastBack71 Modular Mustangs 2 December 12th, 2006 07:30 PM
Engine ID Numbers madstang87 99-04 0 October 7th, 2006 08:11 PM
