Transmission problem help please
ok i have a 2000 v6 mustang i established that i have a t-5 trans
1352-260 is the id number but anyway my 2nd gear is not working well i can shift into it at a high rpm from first but it still grinds i can down shift however eaisely if im sitting still i can push back on 2nd gear not using the clutch an the syncros will pull the car forward some so i dont think its syncros how many problems do t5s have with the shift forks in the tranny is it likely theat i bent it. |
bump, i've been interested to hear about gearing solutions for some time now...would like to see the answer.
[quote=Speedstang302]nice...stallion...10...good job..only took you 20mins...not bad...Someone get out a camera...future post whore in the making..[/quote] [IMG]http://i46.photobucket.com/albums/f143/pwit/Randelman1.gif[/IMG] |
mine did that, it finally got stuck in 2nd, put a 150 dollar rebuild kit in it & it's good as new!
www.hsvracing.com |
I had the same thing happen sometimes it would go into gear and other times it wouldnt it turned out to be a broken shift fork its a cheap fix if you can pull the tranny yourself and take it to have it fixed
#5 | |
well sounds like to me you have been banging the shit out of those gears like i told you not to bro lol.. im still beting on the syncros for the simple fact she wont take second at high rpms yeah you rev it there but by the time you actually make the shift there down around like 2000 or so..
48.47@ 12.58
welcome to the forums 5.0literkid
Threads Similar to: Transmission problem help please
| Transmission or Clutch problem ? | cobralini | 5.0 Mustangs | 7 | May 23rd, 2007 11:44 PM |
| Transmission Problem? | ricer_slayer | 5.0 Mustangs | 12 | February 26th, 2007 07:32 PM |
| 2004 Automatic Transmission Problem | bdoss | V6 Mustangs | 0 | January 10th, 2007 01:43 PM |
| Transmission Problem | 623MUSTANG | 99-04 | 4 | August 10th, 2006 03:29 PM |
| Transmission Problem | 173speed | 5.0 Mustangs | 6 | April 13th, 2006 10:57 PM |
